04-30-2012, 09:11 PM | #1 |
83 K10 to C10 Frame Swap Question
I have a 83 SWB K10 4x4, but want to swap my cab/bed/front clip over to a 2x4 SWB C10 frame. My question is this; will any 73-87 C10 SWB frame work, or do I need a 81-87, or will only a 83 frame work? What differences in frames do I need to look out for? Thanks for the help!
05-01-2012, 12:20 PM | #2 | |
Re: 83 K10 to C10 Frame Swap Question
05-01-2012, 02:23 PM | #3 | |
Canadian Trucker
2020 Silverado Trail Boss - 6.2/10spd |
05-01-2012, 08:45 PM | #4 |
sell it and buy a 2wd they are way easier to find 2wd than 4wd
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903 |
05-03-2012, 09:35 PM | #5 |
05-03-2012, 09:37 PM | #6 |
That's what I was thinking, I just wanted to be sure. Parts are so interchangeable on these trucks, but there's always that oddball part that changes everything up.
05-03-2012, 10:00 PM | #7 | |
05-03-2012, 10:56 PM | #8 |
I swapped my 77 2wd to 4wd, it worked out, just had to re-drill alot of the holes. If you have a complete doner to swap from and get all the measurement then its not too bad.
1981 Dodge D-150 (under construction) 2007 Chevy Suburban 2010 Dodge Charger R/T 1980 Kawasaki KZ 440 2004 Harley Sportster 1200 |
05-04-2012, 12:09 AM | #9 |
That's a nice truck!!! Why not just keep it like it is? Maybe change the tires to something not as aggressive as those.
My Projects: 1960 GMC 1/2ton with 305 V6 (daily driver) 1963 Chevy 1/2ton 2wd...converting to 4x4 1967 Suburban 1/2ton 2wd My Girlfriends Projects 1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver) 1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam 1978 Camaro Z28 |
05-04-2012, 09:30 PM | #10 |
Thanks! I've enjoyed the truck like it is since the restoration in 2006. I want to keep the truck for sentimental reasons, but I'm wanting something different. I want to do a 2wd swap w/ a 6.0L LQ9 and a T56, as well as finish some things on the interior that were not in the budget back in 06.
05-07-2012, 04:47 PM | #11 | |
sorry i got alittle carried away there with photobucket....all well, we all love "truck porn" lol |
05-07-2012, 08:32 PM | #12 |
Do you like black or red better???? Those are some very tastefully built trucks you've done. The black one with the full trim package makes me want to put trim on mine someday. Those are great looking trucks!
05-08-2012, 02:43 AM | #13 | |
The plans you have for your engine/trans combo is what I've been thinking/dreaming about putting in my 83 camaro....but that's a ways down the road, my 63 is priority number 1 right now.
