question about glove box option sticker
I was just going through the original paper work on my 66 short bed and noticed that my original glove box sticker says engine conversion on the top left. Has anyone else seen this before?
Re: question about glove box option sticker
I was actually sanding my glovebox today wondering what sticker used to be on the inside of my glovebox door. Any idea where the truck was from? Mine came from california and had an air pump on the 250 inline engine which could have something to do with engine conversion? I also have similar options listed on the build sheet behind my seat just wasn't originally a custom like yours.
#3 | |
i will have to check that out for you, it is very hard to see because of the springs and is very brittle so i dont want to tamper with it too much. ill look tomorrow night. and get back to you. Also i have a decal on the instrument cluster that says "do not maintain speeds over 60mph" and there is light which says "over speed" which i assume comes on in that case.
http://67-72chevytrucks.com/vboard/s...d.php?t=515355 here is my truck. i have made some progress since then. |
Truck must have been assembled in California. Most OR, WA trucks came from Fremont CA. Should find a Z code on VIN. California had tougher smog laws,In 1966 air pumps were first installed on CA 1/2 tons while 3/4 tons with the same engine did not have air pumps. Conversion would be to remove or add smog equipment depending on model and what state delivered to.
#6 | |
![]() Join Date: Aug 2010
So, did all CA C-10's have smog equip originally in 66? Vehicles this old are smog exempt now, so it's no wonder you don't see the equipment in place anymore. |
![]() Join Date: Aug 2008
my 66 that i sold had the engine conversion on it it was shipped new to denver colorado i thought it might be a carb jet change? for the higher alitude .
i looked at my other two fremont trucks one from salem oregon anf the other from chino ca they do not have the conversion they are 3/4 ton 327 engine. the chino truck does have closed pos vent listed on the tag . it has a screw on oil cap verse the push on does anybody have this as well?
#9 | |
on v-8 the oil fill cap isa push on in most case but my cal. truck is a screw on type i will get some pictures
here are pictures
![]() Join Date: Sep 2009
i am not sure about 66 trucks with smog pump but i had a 68 panel truck with 250 six and smog pump. a guy i worked with had a 68 panel truck with a v8 and had no smog pump. his was legal because when we owned them you had to have them smogged
