#1 | |
Bloo
how to wire up points distributor?
ive got a black wire runnign from the coil to the points, what else do you have to wire up on one of these things? i hate to but im going to drop this thing in until i get my HEI so i can get it running.. the cap, wires, and points are new so it should work decent untill then
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
Fabricate till you "puke"
the black wire from the dist goes to the - side of the coil(you have that allready). The white cloth covered wire from the harness goes to the + side of the coil.....white & yellow are together at the coil, & yellow goes to the soleniod. good luck, crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
