Old 05-01-2012, 12:42 AM   #1
54Caddy
GM Addicted
54Caddy's Avatar
A-Arms Bolts
Well my right front upper a-arm alingment bolt backed it self out somehow and all shims fell out. So i figured i might as well re-lower it using spindles and coils so i did that yesterday. Used 3 inch spindles and 2 inch coils. I checked today and the dang bolt backed it self out again and i lost 1 shim. Why would it keep backing out? Should i put some blue locktite on it, then a nylock jam nut also to insure it wont loosen again? anyone do there own camber caster adjustments at home??
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline   Reply With Quote
Old 05-01-2012, 11:46 PM   #2
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: A-Arms Bolts
The nuts are friction lockers so they are slightly pinched. After a while they get worn out so does the bolt threads. Replace these and you should be all good
http://www.classicparts.com/Chassis/products/387/3/0
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 05-02-2012, 12:37 AM   #3
54Caddy
GM Addicted
54Caddy's Avatar
Re: A-Arms Bolts
so just replace the whole stud? Today i just torqued them all down then installed a jam nut in front of them see what happens
..Mac’s Garage..
IG:MacsGarage
Old 05-02-2012, 02:01 AM   #4
INSIDIOUS '86
Re: A-Arms Bolts
Double nut can work.
Old 05-02-2012, 04:58 PM   #5
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: A-Arms Bolts
You need to use what is called a "Prevailing Torque Nut" its a use once throw away nut. Nylocks are not used in suspension work ever because they back off.
dwcsr is offline   Reply With Quote
Old 05-04-2012, 10:37 PM   #6
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: A-Arms Bolts
I don't agree with Dave. Nylock nuts are spec'd for applications up to 450 degrees temperature. They work fine on suspension or any other non hi-temp applications.
