Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 05-01-2012, 11:49 AM   #1
dukcaln
dukcaln's Avatar
ipod- to amp, no deck. need info
so up until yesterday i was going to inslall my stereo, amp and subs. But after realizing my son will never use the deck and with the recent theft in the ara I decided to look into the option of ipod and amp only. I did a really quick search and found a kit from an online audio store that comes with the jacks, cable, switch and such. can somebody please post a link or info on this, basically how to hook it up, what kind of amp ect.....
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP
SOLD 1972 chevy c10
dukcaln is offline   Reply With Quote
Old 05-01-2012, 12:32 PM   #2
tubbedII
needs more $$$
tubbedII's Avatar
Re: ipod- to amp, no deck. need info
Install the amp as normal, but hook up the remote wire on the amp to either an ACC link or to a switch he can turn on/off manually (If the later is used, I'd still use an ACC hot rather than a constant hot so the battery isn't drained). After that, all that would be needed is a wire with an audio jack that splits to RCA's as the easiest solution.
Take a look at pre-amps though as I hear it's best to run these between the ipod and amp for clarity. I've never looked into these though, so I'm of no real help here.
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 05-01-2012, 01:31 PM   #3
OC 72
OC 72's Avatar
Check out April issue of Custom Classic Trucks...they have a good article on the Kicker amp install.
OC 72 is offline   Reply With Quote
Old 05-01-2012, 10:43 PM   #4
dukcaln
dukcaln's Avatar
great thanks all
SOLD 1972 chevy c10
Old 05-02-2012, 10:10 AM   #5
Normru45
http://67-72chevytrucks.com/vboard/s...d.php?t=515528
this is what i did, hope it helps.
Normru45 is offline   Reply With Quote
