six speed swap?
Looking for information on swapping a six speed manual transmission in a 1982 1 ton srw chevy 4x4. Truck has a 502 bb with a factory 4 speed and 205 transfer case. Has anyone done the zf 6 speed swap or maybe a 5 speed swap. Just trying to get the facts on doing it right. Might be talked into an automatic overdrive also but I really would rather stick to the stick. Thanks in advance.
Re: six speed swap?
A NV4500 5sp is a pretty easy swap almost a direct bolt-in.
1999 Chevy K2500 RCLB 350 4L80e 2004 Chevy 3500 C&C Dmax Allison |
Re: six speed swap?
Thanks ledgendman,
You don't happen to know the year truck I want one out of do you? It will fit the 205 transfer case also? |
Re: six speed swap?
91-to some year I forgot, the later ones are better but the early ones had a lower first gear.
Hope it's ok to post this here, thread on one in a k30 with a 6.2 diesel http://www.dieselplace.com/forum/sho...ghlight=nv4500
Re: six speed swap?
Thanks for the thread. I think I can learn most of what I need from it. Any knowledge on the newer six speed?
#6 | |
Re: six speed swap?
No info on the 6sp, only did research on the nv4500 because of the availability.
![]() Join Date: Dec 2010
Re: six speed swap?
I wanted to originally go with a ZF 6-speed in my truck but it became a royal pain trying to get it all together - let alone find a good donor trans assembly... My recommendation is to do what I did - just stick with an NV4500 5-speed - easy to find & easy to swap!
1977 Chevrolet K30 LWB Crew Cab 497HP Mast Motorsports 6.0L LY6 HO engine GM NV4500 5-speed, Centerforce clutch + NP205 D60 + 14-bolt FF w/ Eaton posi + disc brakes Skyjacker 2.5" full spring lift w/ Nitro shocks Custom paint + interior http://67-72chevytrucks.com/vboard/s...d.php?t=435722 |
Re: six speed swap?
Thanks to you both, I will probably do just that. Will start looking for the nv-4500. Thanks again.
Re: six speed swap?
how much modification would be needed to instal a nv-4500? I have an 86 gmc with the same exact setup he does. 4 speed with granny gear and a 205 transfer case.
1986 GMC K15 4.3V6/SM465/NP205 will be converting to 5.3LS E-ROD/AA adapter/SM465/NP205 10 Bolt Axle Rebuild Tutorial: http://67-72chevytrucks.com/vboard/s...d.php?t=536415 |
Re: six speed swap?
Correction i have a 208 transfer case
Re: six speed swap?
What is the difference in a 205 and 208 transfer case?
Re: six speed swap?
From what ive read the 205 has gears that directly connect rather than the 208 which has a chain which connects the shafts
