05-01-2012, 09:45 PM | #1 |
Mount wood bed without the wood???
Hey everyone I have a 71 C20 with a wood bed. I just recently got the truck driving again. I pulled the entire bed off and tore it apart to clean repair and rebuild.
Now since it is a wood bed I need the wood in order to mount it to the truck correct? I've never done a wood bed before that's why I ask. I won't have the money for the wood nor the bolts for some time now that's why I'm asking. Posted via Mobile Device |
05-01-2012, 10:32 PM | #2 |
Re: Mount wood bed without the wood???
You really need wood to hold the bed up and bolt it down. Might be able to get by with planks in a couple of strategic locations though. Here is a link to a page we have been working on the last couple of days.
http://67-72chevytrucks.com/vboard/s...d.php?t=522017
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
05-02-2012, 04:34 AM | #3 |
Might try a couple sheets of plywood. Won't look great, but it'll get you on the road...
1960 C-10 2000 Dakota R/T 1966 Fury I 2dr post 1984 Big Bronco 2002 Durango SLT (Bride's Ride) |
05-02-2012, 06:47 AM | #4 |
Definitely need something at the mounting points or you'll have 3/4"of slop. The bed will be sagged and jump up and down. At least that's how some of mine got when the wood rotted
05-02-2012, 08:28 AM | #5 |
I've had a sheet of plywood in mine for 5 or 6 years with bolts from Home Depot ... some day i'll get a proper floor. (I have had to replace the plywood a couple of times, as it sits in the weather year round)
'69 short step with dreams of being a hot rod You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape. |
05-02-2012, 12:25 PM | #6 |
I'll probably do the plywood idea I don't like it but I'll have a working bed.
