Old 05-02-2012, 12:24 AM   #1
Lockedup
Lockedup's Avatar
Astro Van front clip?
Hey guys, I was looking at a astro van front end i have laying around (has a 4.3 i need to pull) and am wondering if anyone has installed one of these in our trucks? From what i can tell there very similiar to an S-10 beside the steering box? I tryed searching and found nothing, so is this a possible option?
1957 Big window - Full roller 400 SBC-TH-350-12 bolt- Lowered 3" - Cragar wheels
Lockedup is offline   Reply With Quote
Old 05-02-2012, 08:15 AM   #2
54 jimmy
54 jimmy's Avatar
Re: Astro Van front clip?
they have a 5on 5 bolt pattern. i think the clip will be too short as the van has a shorter nose than the s10. so you will have to addto the front of the clip. the engine sits a little farther forward in the astro clip compaired to the s10 or camaro. also it is a little wider than the s10 or camaro clip. hope this helps.
There is nothing you can't fix with a BFH or a FIRE WRENCH.
1997 chevy k1500 ext cab z71 (daily driver) sold
1996 chevy k1500 reg cab 4x4(daily driver)totaled
2008jeep patriot (wife's daily driver
2008 chevy 1500 ext cab 4x4 sold
2011 chevy 1500 crew cab ltz (daily driver)
1996 chevy 1500 reg cab 4x4 project sold
2006 pontiac grand prix gxp (daily work commuter)
54 jimmy is offline   Reply With Quote
Old 05-02-2012, 12:07 PM   #3
_Ogre
_Ogre's Avatar
i can't say about the clip
but save the steering column
i used an 86 astro column in truk
shop air compressor timer
Old 05-02-2012, 02:32 PM   #4
bjcaldwe
bjcaldwe's Avatar
I did not know they had a 5 on 5 bolt pattern. Any idea how wide the rearends are?
My AD Truck Build Thread
52 GMC one day laying on the running boards
2004 Chevy Crewcab. 3/5 and notched
bjcaldwe is offline   Reply With Quote
Old 05-02-2012, 02:42 PM   #5
bretcopsey
My daily is a 94 Astro. 5x5 bolt pattern is correct. I can see if I can get axle width for you, but they are not supposed to be great for handling any real power. They have the "gov/lock" differential.
My 51 project
http://www.cardomain.com/ride/2285825
My 68 Camaro project
http://www.cardomain.com/ride/2277404/1
bretcopsey is offline   Reply With Quote
Old 05-02-2012, 08:12 PM   #6
Daze57
Daze57's Avatar
i would stick to what works ! camaro - firebird etc -- lot of info on theses and they work well just my 2 centavos worth
Daze57 is offline   Reply With Quote
Old 05-02-2012, 10:29 PM   #7
waybad
waybad's Avatar
check out the track width,,, they are very wide!
waybad is offline   Reply With Quote
Old 05-03-2012, 12:12 AM   #8
mr48chev
mr48chev's Avatar
Hub to Hub with on the Astro vans is right at 62-1/2 inches which is pretty wide for most older rigs.
Probably the best thing to do is jack the truck up, pull off the front wheels and measure the width from mounting surface on one hub to mounting surface on the other hub. That will give you a base measurement to go by.
Then you need to add the wheel tire combination you plan to run into the equation. Will the setup you want to run fit? Next, do the wheels you want to run come in the 5 on 5 bolt pattern?
Old 05-03-2012, 11:05 AM   #9
mknittle
mknittle's Avatar
5X5 is a common pattern for Ford trucks that use 9" rear ends. hmmm?
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 05-03-2012, 11:59 AM   #10
G&R's57GMC
G&R's57GMC's Avatar
Most were 5 on 4.5 .
If you were to order a 9" from Currie you can get different patterns. Call and ask about all the options they offer for their 9".
G&R's57GMC is offline   Reply With Quote
Old 05-03-2012, 12:23 PM   #11
jimig1
jimig1's Avatar
If you are looking at a used 9" you can have the bolt pattern redrilled. Mine was a 5 x 5.5 and had it redrilled to 5 x 4.75. it was only $75 to get it done locally. I have less then $300 invested in it with disc brakes.
55 2nd series Chevy Pickup
2019 Chevy Equinox(Daily driver)
2011 Chevy Malibu (Wife's car)
MSRA Member
I went to a bookstore and asked the saleswoman, "Where's the self-help section?" She said if she told me, it would defeat the purpose.
-George Carlin
jimig1 is offline   Reply With Quote
Old 05-03-2012, 01:41 PM   #12
mknittle
mknittle's Avatar
And if I hit the lottery I could.............
Sorry 5X5 on trucks cars are 5x4.5 that is why we use ford truck rotors on our jeeps
Mark
My GMC build.
Old 05-03-2012, 01:54 PM   #13
mknittle
mknittle's Avatar
Yeah that works. I did that to the flywheel in my jeep went from a tiny 9" Ford clutch to a 11" gm.I drilled and reamed & taped the holes on a bridgeport mill and had the surface ground flat.
Mark
My GMC build.
