05-02-2012, 04:13 AM | #1 |
th400 trans module vacume help
My 85 k20 has a 400 new trans. Where is the best place to hook up the vacume line for the module right now i have a metal line going from module to intake area than it goes into a rubber line which goes into intake it leaks some is there a better way to run the vacume thanks
Posted via Mobile Device |
05-02-2012, 11:59 AM | #2 |
Re: th400 trans module vacume help
Why is that such a problem? fix the leak. The trans needs constant manifold vacuum
05-02-2012, 02:02 PM | #3 |
My question is what is the BEST way to tie the metal line to the intake. The right and clean way
If your answer are smart ass answers just keep it to yourself The purpose of a forum is to help each.other.out If i.am wrong let me know I will leave there are other forums..... Posted via Mobile Device |
05-03-2012, 08:11 AM | #4 |
Replace the rubber portion of the line into the stock location. Make sure it is the right size and you should be good to go. kwmech may not have intended to give you a smart ass answer. It may just be he is trying to say that you don't have to reinvent the wheel with this situation.
