Old 05-02-2012, 08:54 AM   #1
lss1
5.3l swap in 72 blazer
Hey all I'm a long time reader but a first time poster. I just wanted to say this is a great site full of good info and helpful people. As you know by the title I have swapped a 5.3l engine out of a 03 silverado into my 72 blazer and I am having a heck of antime trying to figure out how to get the power steering high pressure side to work. I have been doing some reading but nobody has come right out and said here's what you need. So I know the swap has been done many times but what did you do to make it work? I don't really have any hose manufacturers around me so if there's an adaptor or somebody I can call I would greatly appreciatte it. The trucks running and this is the only thing holding me back. Thanks fellas in advance for the help.
lss1 is offline   Reply With Quote
Old 05-02-2012, 09:07 AM   #2
SamMargritz00
SamMargritz00's Avatar
Re: 5.3l swap in 72 blazer
wow i don't recal having any problems when i did mine. ill have to look and see what i have on mine. but im sure someone will chime in on it.
SamMargritz00 is offline   Reply With Quote
Old 05-02-2012, 12:46 PM   #3
lss1
Hmmm interesting...did you use the factory 72 blazer line to the ps pump then? I might be going at it wrong as I'm trying to adapt the 03 silverado line to the 72 blazer gear box. The factory gear box on the blazer is an inverted flare and the high pressure line on the 03 silverado is a oring style line....
Old 05-02-2012, 12:52 PM   #4
SamMargritz00
i remember now...i made my own lines. i bent the power steering lines when i was bending the fuel and brake lines throughout the whole thing. just made my lines from the pump to the resivour with the different styles if i remember right.
Old 05-02-2012, 01:27 PM   #5
lss1
Ok so you used the factory 5.3l lines and then cut off the oring fitting that would gononro the gear box and flared it yourself? Man I'd think somebody would make a line or an adaptor for this application with as many of these swaps being done...
Old 05-02-2012, 02:39 PM   #6
JMac11
JMac11's Avatar
Don't hold me too it, but I believe the fittings out of the modern steering box come out and will thread into you old steering box. Basically the steering boxes are machined with the same threads.
JMac11 is offline   Reply With Quote
Old 05-02-2012, 03:42 PM   #7
SamMargritz00
no i made my own lines. every line in my blazer started out as a straight piece then bent them and put my own fittings on the end...but i don't think i had the problems your having.
Old 05-02-2012, 04:26 PM   #8
Firebirdjones
All you have to do is remove the high pressure fitting from the back of your old pump,,,,and it screws right into the back of the new pump,,,then you can use your factory lines, works just fine.
That's how I did mine. Really simple solution that doesn't cost a dime.
Firebirdjones is offline   Reply With Quote
Old 05-02-2012, 06:08 PM   #9
lss1
Oh perfect!! I guess I didn't realize the old 350 ps pumps had an adaptor fitting in them. I will get one hunted down! Thanks for the info!
Old 05-02-2012, 07:23 PM   #10
Firebirdjones
Actually just about any old style power steering pump should have the same fitting. I don't think the flare size or threads changed throughout the 60's and 70's.
It's about a 1" nut size, it unscrews with a spring behind it, so be ready.
