ECE Spindle Guys
Do any of you have any clearance issues? I have 15x6.5 rally's on mine and I have heard the offset my be of an issue.
I'm looking at their 2.5" drop spindles with a regular stock replacement coil and 4" drop springs for the rear, and I want to make sure before I pull the trigger that there wont be any issues. Thanks! |
Re: ECE Spindle Guys
i also have this same question.
Here is one more option for you we do carry Cpp spindals and Cpp dropped & stock springs that will work for your application no problem at all.If you are interested you can p/m me or e-mail me at justin@scottshotrods.com or call me at (805)485-0382
Justin |
Why was this post moved?
Just a question, nothing more too it. |
Happy to be here
![]() Join Date: Mar 2000
I did not move it, but my guess is so it would get more attention. Now that its in the Suspension Forum our resident experts will see it.
I have a set of ECE spindles, and did not have any issues with clearance on my rallys.
Steve
1970 Gmc Grande Sierra Swb 2wd LSX (LQ4/4L80e) 1990 K1500 Daily ![]() |
67-72 parts collector,…
![]() Join Date: Nov 2002
The 15x6.5" and 15x8" truck ralley wheels have a 4" BS.
The 15x7" truck ralley wheels have a 3-5/8" BS. 15" wheels with a 4" BS wll require trimming of the lower a-arm in the lower ball joint area,... for trucks running the standard design 2.5" and 3" drop spindles. (removing a little of the "gutter" on each side of the balljoint) This takes about 5 minutes per side with a electric grinder equipped with a cut off wheel.
That sux. I am running 15x6.5 rallys on 235/75/15 all the way around. I'm looking at the 2.5" spindle.
I dont want to have to shave anything off if I buy the spindles. Can you explain where and what would have to be cut off? I guess the alternative is to get the drop spring and the shock relocators? jackyl9999 what size are you running with no issues? |
15x7
#10 | |
The blue tape marks the areas that were previouly trimmed. I've been doing this mod for over 25 years. I do it on all trucks I lower with drop spindles. (you never know when you might have to bolt on a different set of wheels)
Ok, so I should just concentrate on the blue tape then?
Is it the entire length of the tape? How much approx do I need to shave off? Or is it more trial and error? Any other areas to be trimmed? |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Just bolt the wheel on to the truck and swing the steering side to side. You'll see where the wheel lip hits the control arm. It's completely self explanatory when you see it in person. Like Keith said, 5 minutes and you're done. Like him, I've been doing it since the early 90s on many trucks. Heck, I just did my own truck last week. Don't sweat it. It's a non issue.
#13 | |
![]() Join Date: Jul 2007
Chuck 68 ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=374892 My trailer redo http://67-72chevytrucks.com/vboard/s...69#post5893869 Chuy my 59 bug http://67-72chevytrucks.com/vboard/s...d.php?t=653798 Putnam 87 GMC Shop truck http://67-72chevytrucks.com/vboard/s...d.php?t=707687 |
#14 |
68 C 10
![]() Join Date: Aug 2010
My truck has a 84 model crossmember put in by the PO will this trimming still be the same on the newer style lower arms?
Kevin "Life is Hard But its Harder when your Stupid" John Wayne 68 C10 70 C20 http://67-72chevytrucks.com/vboard/s....php?t=602326# |
#15 |
Yes.
#16 |
68 C 10
Thanks Keith
#17 | |
66 GMC Suburban Custom 66 Chevy K10 Suburban |
