05-02-2012, 11:00 AM | #1 |
BB wood bed floor heat shields 55$
I have a set of original BB wood bed floor heat shields. $55 shipped to your door. thanks Jenn
Specializing in OEM 67-72 Chevy & GMC parts since 2001 1969 GMC Longhorn 396 1969 Chevy 3/4 ton LWB 396 1983 Toyota pickup 22R 2012 Toyota Scion Xb |
05-02-2012, 11:46 AM | #2 |
Re: BB wood bed floor heat shields 55$
Was there a difference between the BB and SB, why would the engine size make a difference?
Cheers, |
05-02-2012, 11:57 AM | #3 |
Active Member
Small block trucks prob did not even have them them, and if they did would only have one, on the drivers side.
As you know big block trucks came factory with dual exhaust and with an exhaust heat shield on the firewall/floor board. |
05-02-2012, 12:40 PM | #4 |
70+ ( Old Skool Club )
Did Big Block trucks come with 2 heat shields? Do they bolt to the frame. I am interested in them because I have a new wood floor going in my original samll block truck and am wondering if the holes would be in the frame or crossmembers to bolt the shields on my truck.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
05-02-2012, 03:07 PM | #5 |
All of the heat shields that I have found, were ONLY on BB wood bed trucks. That is whyI listed these that way. They stop your wood bed from catching on fire. I also have the hea shield on the cab for BB. This was to prvent your FEET from catching on fire. hahahahahahahah. If you have ever been in a BB truck with no carpet, you know what I am talking about. Also the heat shields attach to the wood slats on the underside of the bed. thanks Jenn
05-02-2012, 03:23 PM | #6 |
Loves all GMC trucks
Ill vouch for that! My daughter hates riding in it with flip flops on. lol
05-02-2012, 03:53 PM | #7 | |
05-02-2012, 04:52 PM | #8 |
Yes the screw to the wood itself. You can google images of the heat shields and you can see them installed. Basically you would install the shields where the exhaust is closest to the bed (usually right behind the cab).
I want $55 shipped. Or 45$ not shipped. If you want them, You can pay me the hole $55 and I will hold them for you, and if you come get them from me I can give you the $10 back. Let me know. jenn
05-02-2012, 05:27 PM | #9 | |
05-02-2012, 05:49 PM | #10 |
That is fine. Jenn
05-02-2012, 06:10 PM | #11 |
I will take them
05-04-2012, 12:37 PM | #12 |
These are sold!!!
