05-02-2012, 03:33 PM | #1 |
New!: Wilwood D154 Rear Brake Kit
Wilwood just released a brand new rear disc brake kit that uses the D154 caliper. This caliper resembles the D52 very closely. I wanted to share this new kit with everyone and let you know it is available:
$770 for slotted / drilled rotors $670 for plain rotors We offer Free Shipping on this item as always. Features: 12" Rotor Integrated Parking Brake 2-Piston Caliper Red or Black Powdercoated Caliper D154 Rear Disc Brake Kit |
05-02-2012, 04:31 PM | #2 |
Re: New!: Wilwood D154 Rear Brake Kit
What about dimpled rotors? And what woul the cost of replacement rotors be? Both plain and fancy
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
05-02-2012, 06:39 PM | #3 |
Wilwood just has the drilled / slotted rotors available. Replacement rotor pricing is below, but keep in mind, that rotors aren't replaced very often. But, I do agree, good to know what they cost if it is needed.
Plain Rotor: $158 ea. Drilled/Slotted Rotor: $215 ea. I was glad to hear they finally came out with a more affordable rear disc kit. I think for the price, it is a nice system with the integrated parking brake. |
05-02-2012, 08:04 PM | #4 |
Some spendy rotors. But glad to see the kit is very affordable indeed.
Now are the calipers upgradable or is that a whole other kit entirely? Would have liked seeing a 13" rotor option Posted via Mobile Device
05-02-2012, 08:43 PM | #5 |
Calipers aren't upgradeable, as it would require a new bracket. By the time you get the new bracket and bigger caliper, you would probably be at the cost of the next kit up.
This is the nextstep up with a 13" rotor 13" Wilwood Kit Baer 13" Rear Kit is a little more affordable considering the Wilwood 13" kit. SS4 13" Baer Kit |
05-03-2012, 09:21 AM | #6 |
what kind of kits do you have available for k30's. I already have rear disc brakes on my corporate 14 bolt FF and they are the same calipers that are on the front of a k20. But my front calipers are quite different. They have the pin that drives in to hold the caliper in place... which I believe is specific to 1 tons... Not sure. Any information would be nice.
1986 Chevy Silverado k30: factory air, tilt wheel, 454cu 7.4L, Turbo 400, NP205, Corporate 14 bolt, Dana 60 front, 4.10 gears, SRW, long bed, standard cab... MY TRUE LOVE |
05-03-2012, 10:17 AM | #7 |
Slots go on anything!
Is there any chance these will clear 15" wheels?
1974 Jimmy- 5.3/4L80e/NP241 |
05-03-2012, 04:59 PM | #8 |
Wilwood claims a 16" is the smallest. I will have the actual digram of the brake soon, and I can let you know what the overall diameter of this brake kit. It may fit inside some 15" wheels, depending on the style and where the drop center is.
I will keep you posted. |
05-03-2012, 08:41 PM | #9 |
The radius of this kit to the top of the caliper is 7.5" (15" diameter), so I don't think this is going to work inside a 15" wheel.
05-03-2012, 08:45 PM | #10 | |
If I come across anything, I will let you know. Just from my searching today, I couldn't come up with anything in a aluminum style aftermarket caliper. |
07-01-2015, 10:53 PM | #11 |
PM sent on 6-29. Please let me know prices when you get a chance.
Thanks, Karl |
07-02-2015, 12:06 AM | #12 |
Does this kit come with everything needed to convert? Has the price changed in the last few years? Do they offer a matching front kit? Thanks for any info!
2018 Audi S5- wife's ride 1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511 1981 Chevy Silverado- in pieces 1964 Chevy c10 2017 Jeep Wrangler JKU |
07-02-2015, 08:28 AM | #13 | ||
The best matching front kit, would be the D52 swap calipers. We do have a front and rear kit, that uses the D52's up front, this kit in the rear, new rotors up front, SS hoses and e-brake cables. http://www.azproperformance.com/Pro1...Brake-Kit.html - Travis |
07-02-2015, 08:36 AM | #14 |
Awesome thanks! I'll be saving up for that.
07-03-2015, 08:25 AM | #15 |
What kind of parking brake does it use? Similar to the late 70's Cadillac/Camaro or the newer little drum in the rotor?
Nevermind.... I looked it up. small drum style Last edited by bdiamond; 07-03-2015 at 08:33 AM. |
07-05-2015, 07:38 PM | #16 |
In the Forgotten far North.
How's about a rear disc conversion for an 87 1 ton 2wd crew cab dually?
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
07-06-2015, 12:06 PM | #17 |
Unfortunately I don't have anything for the 8-lug stuff, in regards to brakes.
07-07-2015, 02:16 PM | #18 |
Do they make a complete front and rear kit? 1974 c10 with 1.25 front rotors. DJM 3 in drop spindles.
07-07-2015, 11:19 PM | #19 |
$770.oo for one disc brake setup. So you have to buy another for the other side?
07-07-2015, 11:36 PM | #20 |
That's a pair
01-05-2016, 01:38 PM | #21 | |
I am getting this rear kit for my C10. You said there is an adapter for 25 bucks? Do you have them available? or part number? Does that mean you can incorporate the stock cable with the adapter?
Thanks, Casey 71 Chevy C-10 SWB 350/400 PS, PB The Build http://67-72chevytrucks.com/vboard/s...d.php?t=584045 The Brake Upgrade http://67-72chevytrucks.com/vboard/s...d.php?t=695699 |
01-05-2016, 05:16 PM | #22 |
The adapter clevis is Lokar PN: EC-80WC
01-07-2016, 09:18 PM | #23 |
STILL PLAYS WITH TRUX
Is the parking brake a built in drum style in the rotor or the goofy mechanical lever on the caliper type?
01-08-2016, 10:20 AM | #24 |
Yes, it is a parking brake assembly inside the rotor.
01-08-2016, 11:20 AM | #25 |
Happy to be here
Digging up bones. Travis, what about a proportioning valve? What will you need ?
