Attaching C-10 fender emblems
When I built my 68 C-10 six years ago, I painted it in pieces and was able to install the C-10 fender emblems before re-assembling the truck. I am presently having the truck professionally re-painted, but without disassembling it. To remove the fender emblems, I unbolted the fenders at the bottom, sprung them out about 1-1/2" and, utilizing a 3/8" Gearwrench taped to a stick, backed off the speed nuts. A very arduous process, to say the least.
Anybody out there have an easier solution to re-installing those C-10 fender emblems? |
Re: Attaching C-10 fender emblems
I used some barrel clips like is used to hold on the center tailgate chrome over the handle. Worked really well
1968 chevy lwb, getting ready to join forces with the 70 gmc 1970 gmc swb, getting ready to be a 68 chevy swb 1971 gmc lwb 2500 2wd Sierra Grande 1988 chevy 1-ton crew cab 2wd waiting for a 12v cummins |
not enough hours in the day
You can remove the inner fender for better access to the back of the fender. Another option is to use a barrel clip. The holes in the fender may need to be drilled larger for the clip, then the studs of the emblem just push into the clip.
They look like this. ![]()
65 K-10 Short Step 68 C-50 70 K-5 85 K-10 & piles of spare parts |
I type too slow.
I have used the barrel clips before, don't really like them because they hold the emblem to far away from the the sheet metal. To get the emblem up close and tight to the fender just install them with pal (speed) nuts before putting the fenders on or remove the inner fenders.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
![]() Join Date: Oct 2006
3m double sided tape. Put it on and trim around the emblem. No drilling and no nuts
I actually glued mine on with some quality epoxy. They've been on there for 15 years.
Posted via Mobile Device |
drop the inner fender
