Where do you mount speakers?
I am redoing interior and had the speakers behind seat, I would like them where I can hear better,How many have speakers in the doors? or elswhere? Any ideas?
Re: Where do you mount speakers?
The previous owner of my truck had two installed under the dash. They didn't look quite right so I took them out, but it's still not a bad location if done correctly. Plus, there's not much speaker wire hanging around. I'm sure someone has a better solution or one that's been better executed, but it's a thought.
Thanks for the reply, I just ordered 2 of the old music note chrome speaker covers off of e-bay to mount in the door, will post pictures when I get them installed. Thanks
I have heard of a really good replacement unit for the stock speaker under the dash that performs Very well, Forgot which company Might be LMC
Unfortunately for me I had the bright idea to cut 6 1/2" holes in the doors when I was 16 Best option is probably using a kick panel application |
meowMEOWmeowMEOW
I have two small speakers in the dash (where the single factory speaker would go), and two 6x9's in the doors that the p.o mounted. I will be switching to running some speakers in the center console, where they can be mounted properly and actually sound decent.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
I have a 3 way mounted in each back corner of the cab, facing outward, and one under each side of the seat, facing forward.
![]() Join Date: Jul 2009
Kick panels with Infinity mid-range and tweeters and a sub with back speakers behind the seat........
