05-03-2012, 09:48 AM | #1 |
Sound deadener - on the cheap
I know this has been discussed a lot but this thread is spercifically asking what you guys have used other than the expensive stuff like Dynamat.
I don't want anything petroleum based with the tar smell. I have to cover the entire floor of my K5 Blazer project and my C-10 cab so I don't want to spend a fortune but I want a solid product that will get the job done. Thanks in advance, RIZ |
05-03-2012, 09:59 AM | #2 |
Home Built '87
Re: Sound deadener - on the cheap
I used RamMAAT.
Pretty rerasonable price-wise, good adhesion & easy to work with. Forgot his name but he was helpful & quick to ship.
Gordon 1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424 1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833 Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969 |
05-03-2012, 12:41 PM | #3 |
You can get everything you need from McMaster Carr, it just won't have the name brands on it and will be a little more work to install.
05-03-2012, 01:27 PM | #4 |
Don't Crush em Restore em
TexasJeff 2009 Silver with Linen Interior Cadillac DTS 1990 Red with White Top and Interior Ford Mustang GT convertible 1998 Red with Gray Interior, C3500 Chevy Crew Cab Dually |
05-03-2012, 04:11 PM | #5 |
1967 Suburban 292 3spd 1964 Chevy II wagon 1971 Monte Carlo 402BB 1964 Cadillac series 62 2dr 1964 Bonneville 2dr/ht 1967 GTO 1978 Chevy Van 30 1989 R30 Crew Dually Bonus Cab |
05-03-2012, 04:53 PM | #6 |
Peel and seal. Google it. It's cheap, it works. I did the entire (floor, roof, inner quarters, doors) interior of my mustang for like $75. You can't do a door with Dynamat for $75.
05-03-2012, 06:37 PM | #7 |
how well did this work for you? did it cut alot of the outside sounds and heat out? i jsut found it at lowes and sounds too good to be true type thing.
"Buckle up I wanna try somethin!!" "of course it will hold!, I welded it!" 1977 c10 under knife for full rebuild, 5.3l 4l60e drive rain swap, replacement frame and green repaint |
05-03-2012, 07:20 PM | #8 | |
Didn't notice a reduction in heat, but it was fall when I did it over the course of a month. I did a full interior swap, upgraded from manual to electric windows/locks, lighted visors; along with the sound deadening. Took a little longer than planned. The car has a stock 4cyl in it, so I have no engine heat issues to begin with. I P&S'd the entire floor, under the rear seat, inner rear quarters, a bit inside the doors, and roof. I also put carpet padding under the carpet (a long with the factory jute padding.) I also put the carpet padding behind the door panels, and above the headliner (the factory "insulation" that was up there self-destructed upon removal.) I also stuffed pink fiberglass house insulation in around the rear quarters. The car is much, much quieter. Entirely worth the effort. I still need to P&S the rear package tray and make some sort of sound barrier for behind the rear seat. They make P&S in one, or two foot wide rolls, but needs to be special ordered. |
05-03-2012, 07:24 PM | #9 |
few pictures...
05-03-2012, 07:51 PM | #10 | |
05-03-2012, 07:55 PM | #11 |
Check this out: Sound Deadener Showdown
You don't need to put CLD (Dynamat, Raammat, Fatmat, etc) all over 100% of the metal. Blocking sound isn't what it's designed for. It's designed to add mass and reduce vibrations. Mass Loaded Vinyl is what's designed to block sound. A quick google search comes up with a 4x10 sheet for 75 bucks shipped from this place Put down the CLD tiles in the middle of the panels as needed, then put the MLV on top of that to actually block the sound with closed cell foam in between them as a decoupler. |
05-03-2012, 08:54 PM | #12 |
Use thick rubber mat or "pond liner" and glue it down to the cab floor with spray adhesive. Works the same as dynamat for sound deadening as long as you glue it securely.
05-03-2012, 09:56 PM | #13 |
Mix any old paint you have lying around with sand and apply to cab floor. Very cheap and should work well.
1990 ¾ ton 4x4 Chevy Suburban -Cummins Diesel - 12 valve - factory rebuilt -6 speed bullet proof manual transmission - NV5600 -Gear Vendors Overdrive - HX35 Holset Turbo -NP205 iron transfer case -3.73 gears -2" Lift |
05-03-2012, 11:30 PM | #14 |
im planned on using www.audiotechnix.com when i get the extra cash look up some videos of you tube.
85 GMC sierra classic : 350, 4spd, 205, 3.42s, 35s |
05-03-2012, 11:39 PM | #15 |
People seem to really like the Peel and Seal roofing type products. Here are a couple of threads:
http://www.steelsoldiers.com/cucv/79...t-quieter.html http://www.steelsoldiers.com/cucv/74580-peel-seal.html |
05-03-2012, 11:48 PM | #16 |
Isn't peel and seal asphalt based?
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
05-03-2012, 11:54 PM | #17 |
Using Peel & Seal is not cheaper!
more reading You would have to cover 100% of everything -- twice -- with the Peel & Seal to equal covering 25% with an actual sound deadening product. The math breakdown is like this: Peel and Seal is 16.42 for a 12.5 square foot roll, or $1.31 per square foot. 1.31 times two (because you need to use at least two layers to get close to the same performance) = $2.62 to treat one square foot. CLD price ($3.50) divided by four (since it requires only a quarter of the amount) = $0.875 to treat one square foot. |
05-03-2012, 11:57 PM | #18 |
Yes I think you are probably right although I haven't used it. I realize the thread starter requested something that isn't petroleum based but I don't believe that a tar smell is problem with the Peel and Seal.
05-04-2012, 08:01 AM | #19 |
I used the peel and seal on my crew cab, no tar smell. I installed one layer on everything including roof floor and the doors. I cant get over how quite it is.
Oh yea, 75 bucks and i have enough left to do my regular cab also.
___________________ 78 ccsb dually 5.3 4l60e http://67-72chevytrucks.com/vboard/s...d.php?t=491551 |
05-04-2012, 07:21 PM | #20 |
I used a product called window wrap. It has a sticky rubber coating on the back. Worked well. It is available in building supply stores.
72 Super Cheyenne lwb 4X4 Ocra / White 88 Chevy 1 ton Dumptruck 88 Chevy 1ton Flat bed 4X4 white |
05-05-2012, 08:53 AM | #21 |
Does it have a strong odor??
I guess it would be safe for the doors skins too, since it's made to keep water out. Does it work well as a sound deadener? Trying to decide on a product for my truck which sounds like a tin box. No headliner, I can't hear the stereo. The doors sound hollow and noisy.. Posted via Mobile Device |
