Old 05-03-2012, 11:52 AM   #1
frog210
My truck is bogging out? need help!!!
Hello everyone I have a question
My truck is dying/bogging out on me
When I get between 20-30
My truck starts to bogg out
idk what it is
When i first got the truck
it didnt do that
Then it started to do it
so i took it to this guy i know to rebuild my carb
(Thats what i thought it was)
Worked Fine for like a week
Now its starting to do that again
i have a 74 chevy 350 with a 4 brl quadjet carb
please i need help
frog210 is offline   Reply With Quote
Old 05-03-2012, 02:32 PM   #2
UPNADM
UPNADM's Avatar
Re: My truck is bogging out? need help!!!
Fuel filter is clean?
Base gasket fine?
Is is vacuum or manual secondary? Are vacuum lines good, mechanical linkages free?
UPNADM is offline   Reply With Quote
Old 05-03-2012, 02:38 PM   #3
lifted k10
Is it bogging down to the point that it stalls out, like it's flooded from fuel and trouble restarting unless the gas pedal is held wide open?
lifted k10 is offline   Reply With Quote
Old 05-03-2012, 03:25 PM   #4
HTX86chevy
HTX86chevy's Avatar
fuel pump
HTX86chevy is offline   Reply With Quote
Old 05-03-2012, 03:38 PM   #5
frog210
fuel filter looks clean
Base gasket looks fine( they put a new one on when they rebuilt it
vacuum or manual secondary not to sure about that?
When im going to 20-30 it will yank like forward and back
and will lose power
if i keep my foot on it it will die
i have to take my foot off and let it slow to like 10mph
it wont let me go over 30 mph
so i have to use the side streets
Old 05-03-2012, 05:17 PM   #6
carboncrew
carboncrew's Avatar
My 1986 use to do something similar. Thought it was fuel pump....until I replaced the motor I FINALLY realized it was fuel line going into fuel pump....it was old and getting kinked....sounds dumb but it's helped several people having the same problem. Worth a quick look.
carboncrew is offline   Reply With Quote
Old 05-03-2012, 05:58 PM   #7
frog210
okay im going to take a look at that too wont hurt to look right
Old 05-03-2012, 09:23 PM   #8
motornut
78K & 79C Jimmys
motornut's Avatar
vacum advance or vac leak
the line from the pump to the carb...mine was full of rusty crud,not caught by the filter
and the new fuel pump sure helped
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 05-03-2012, 09:26 PM   #9
frog210
okay i think im going to replace my
In carb filter(paper one)
my fuel filter the glass one
my fuel hose from the pump to the carb
and my fuel pump
is their anything i should do before i change my pump?
any precautions or tips thanks
Old 05-03-2012, 09:28 PM   #10
frog210
and my fuel pump
Old 05-03-2012, 10:33 PM   #11
motornut
78K & 79C Jimmys
motornut's Avatar
safer to do it on a cool block
line pump to carb should have pressure watch for it
if that line is ok to reuse, just blow it out
I use FI clamps, they don't chew the rubber line up
and make sure it's fuel hose!!!
John
Old 05-05-2012, 10:06 PM   #12
mMad Dawg
Something else you might want to check is your coil and coil wire . When thy start to break down they act like a fuel problem. I've had it happen to me before,drove me crazy till I found the problem . Hope this helps. Gord
mMad Dawg is offline   Reply With Quote
Old 05-06-2012, 06:41 AM   #13
Weasel Diesel
Other than the fuel system, If you are running a cat converter they can stop up and cause a heap of problems too. I too would start at the fuel system and make sure that's ok first.
Weasel Diesel is offline   Reply With Quote
Old 05-06-2012, 05:02 PM   #14
frog210
Okay
I replaced the following:
fuel pump
both fuel filters
and it runs great
I think it might have been the fuel pump
Old 05-06-2012, 05:52 PM   #15
HTX86chevy
HTX86chevy's Avatar
Glad to hear good news, good job man.
