Old 05-03-2012, 06:30 PM   #1
chebyshortbox65
chebyshortbox65's Avatar
87 up fuel sending unit in 81 tank
Does anyone know if the tbi sending unit will fit the older tank I picked up 2 I have an 81 with a 5.3 swap and am running in the so cal desert I don't think its going ro last long in the summer heat anytime you idle for a few mins the pump starts whining bad because of lack of airflow I assume anyways I know my tank dosent have the tray in it but this is just temparary I don't let it get below a 1/4 tank anyways.anyone know which pump to use to put out the 60 psi?
chebyshortbox65 is offline   Reply With Quote
Old 05-03-2012, 07:13 PM   #2
ont_guy_38
ont_guy_38's Avatar
Re: 87 up fuel sending unit in 81 tank
I had an older sending unit in a 87 tank , just never showed below 1/4 tank cuz the float hit the tray . Should work ok
ont_guy_38 is offline   Reply With Quote
Old 05-03-2012, 09:22 PM   #3
chebyshortbox65
Thanks for the info
Old 05-03-2012, 11:25 PM   #4
rfmaster
rfmaster's Avatar
Try AC Delco EP381 - this fuel pump was used in 96 to 00 Vortec equipped Trucks and Vans and suppose to be able to deliver 65 PSI at idle. It has similar dimensions as TBI EP386 in tank pump used in 87 to 94 TBI applications.
//RF
"The Beast"
1975 Chevrolet C20 longbed
350/700R4! with 3inch body lift
Dual Flowmasters Super 40's!
TBI retrofit completed (2007-07-29)
New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17)
rfmaster is offline   Reply With Quote
