Old 05-03-2012, 09:00 PM   #1
72 Madness
Gas tank sending unit wiring question
Does anyone know the correct way to wire this up? I have a brown wire coming off of the gas tank. Does it plug into the fuse box? Then the brown wire in the cluster connects to the brown wire coming out of the fuse box? I bought this thing and half of the wiring has been correct. I just wanted to know before I combine anything with gas.....
72 Madness is offline   Reply With Quote
Old 05-03-2012, 10:06 PM   #2
rsavage
rsavage's Avatar
Re: Gas tank sending unit wiring question
Yes the brown wire from the tank plugs into the fuse block - there is a terminal marked "gas gauge". No other wire has to plug into it. Make sure that you have the tank sending unit well grounded with a wire to the frame.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
