Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 05-03-2012, 10:14 PM   #1
mexlokote
mexlokote's Avatar
welder question??
i just bought a 70amp arc welder and it is not working i tried to weld and the electrode just sticks to the metal and doesnt weld? any ideas who can help me,
mexlokote is offline   Reply With Quote
Old 05-03-2012, 10:52 PM   #2
TopFuel1966
TopFuel1966's Avatar
Re: welder question??
Poor ground?
Amperage set too low?
Moisture in the electrode flux?
TopFuel1966 is offline   Reply With Quote
Old 05-03-2012, 10:54 PM   #3
RockTonka
RockTonka's Avatar
70 amps is a very low output welder, I'm assuming you've got a stick welder (SMAW), probably an AC only version?? Without knowing more details, it will be difficult to help.
If my assumptions are correct, than a 6011 type rod would work best for you...easy to weld with, fairly forgiving, will handle a bit of rust or contamination, readily available (Ace, Home Depot, Lowe's). Try the smaller sizes, 3/32 or perhaps 5/64, these will be easier to strike and maintain an arc with.
If my assumptions are incorrect and you have a wire welder (GMAW/FCAW), then we would definately need more details...wire size, type, self-shielded or gas shielded...
1958 Chevy 1 ton dually 4X4 dump/flat bed
My build thread
1966 "Not-So-Original" Chevy Custom Trim Suburban
My Time-Killing Project Truck
1966 GMC Extended cab 1 1/4 ton 4X4
My Son's build thread
RockTonka is offline   Reply With Quote
Old 05-03-2012, 10:56 PM   #4
El Campo
El Campo's Avatar
What side of rods are you using? I use about 125 amps or so when I use 1/8 inch rods. You are going to have to use small rods to use one of that low amperage. Also most new weldors put the rod straight onto the metal and do not pull it off in time (to maintain an arc) and it can stick then. I am guessing your heat (amps) is too low though for the rods you are using. (I am talking about DC welders btw, as I never use AC)
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles
72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2)
2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end
2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED)
2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one)
Hook em Horns!!!
El Campo is offline   Reply With Quote
Old 05-03-2012, 10:59 PM   #5
mexlokote
mexlokote's Avatar
im using 3/32" and 1/16"
Old 05-03-2012, 11:01 PM   #6
71swb4x4
71swb4x4's Avatar
What kind of material are you trying to weld?
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 05-03-2012, 11:02 PM   #7
mexlokote
mexlokote's Avatar
metal
Old 05-03-2012, 11:48 PM   #8
RockTonka
RockTonka's Avatar
Turn the amperage all the way up and strike the electrode like you're striking a match, try to hold the electrode an 1/8 of an inch above the material and maintain that gap as the electrode is consumed.
You don't seem willing to offer much information and our ability to assist is limited by this.
My build thread
Old 05-04-2012, 12:03 AM   #9
mexlokote
mexlokote's Avatar
i bought this http://www.harborfreight.com/welding...der-68888.html
Old 05-04-2012, 12:34 AM   #10
RockTonka
RockTonka's Avatar
Stick with the 1/16" electrodes...this isn't a very good welder and you will struggle with it doing much for you. A couple car batteries in series would do better...for $80 bucks, it's a case of you get what you pay for.
Reading the reviews, it seems that those willing to give an opinion are struggling like you are.
Good luck.
My build thread
Old 05-04-2012, 08:15 PM   #11
GWs62
GWs62's Avatar
RockTonka is right. I am in the welding supply business and I regret to tell you that you will have a hard time welding with anything other than 3/32" electrode as 1/16" is hard to come by. 20% duty cycle is rather low. I would suggest a 6013 rod as it is a much smoother bead and easier to run. Good luck.
When was the last time you did something for the first time?
We never really grow up, we only learn how to act in public.
GWs62 is offline   Reply With Quote
Old 05-09-2012, 02:19 PM   #12
of13swc
E6011, E1012 and E6010 require you to manipulate the electrode. Also depending on the position you are trying to weld, the next to last number on the electrode dictates what positions it can be used for (1 is for all positions, 2 is flat and horizontal and 3 is for flat only). I personally like 3/32” E6010 for my “root” passes the move up to E7018 that stuff lays in real nice. I also agree if moisture got to the electrode it will not run for nothing. Take one of the electrodes and bend it. If the flux breaks off its good but if it bends with the electrode moisture has got to it and it’s no good. With all that said try turning it up until it does not stick. You will have to find the correct amps so it runs and does not burn through your metal. There are a lot more to look for, but without getting into a welding lesson try that first.
of13swc is offline   Reply With Quote
