Old 05-04-2012, 04:25 AM   #1
kylep
kylep's Avatar
little holes in door
i removed the carpet from my door and now i have about 10 holes to fill up. what is the best way to do this without being a metal smith?
I dont want to buy no carpet pieces from lmc, so im trying to do this on the cheap!
Thanks for any and all ideas.
2001 Tahoe
1978 K30
kylep is offline   Reply With Quote
Old 05-04-2012, 04:26 AM   #2
kylep
kylep's Avatar
Re: little holes in door
i have fiberglass ready and willing to go, but will that work? will it adhere enough?
2001 Tahoe
1978 K30
Old 05-04-2012, 05:01 AM   #3
donut
donut's Avatar
Easiest way that I can see is put the screws (or new ones) back in the holes. Personally I don't mind the pseudo-industrial look. A blank screw hole bugs me more.
If I didn't want to weld them up and repaint, that's the way I'd go, but then again, nothing I drive would be mistaken for a show truck.
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 05-04-2012, 07:19 AM   #4
motornut
78K & 79C Jimmys
motornut's Avatar
would something like JB wield work,metal putty
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 05-04-2012, 10:23 AM   #5
silvereagle07
silvereagle07's Avatar
This would be the easiest way if you have access to a mig welder and grinders. Neat nail trick that works great for small holes. http://67-72chevytrucks.com/vboard/s...d.php?t=516695
I've used a panel bond material to fill small holes by dimpling the hole, grind to get metal adhesion , apply tape to the backside of hole (painters tape), fill the hole with panel bond, let dry , sand , apply skim of filler coat, prime, seal and paint. But if I had access I would weld it.
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 05-04-2012, 10:33 AM   #6
tinydb84
tinydb84's Avatar
I've done the bondo route. It took about a year before it became totally obvious. Weld them up.
Old 05-04-2012, 03:57 PM   #7
kylep
kylep's Avatar
thanks for all the replies. unfortunetly im not a welder and dont have one, so im going to try to rig something, gotta put my thinking cap on. maybe ill make my own carpet sides or maybe put something else there?
thanks for telling me the bondo wouldnt work, good to know! if that didnt workt the fiberglass wouldnt either.
2001 Tahoe
1978 K30
Old 05-04-2012, 04:13 PM   #8
grs
Get an 8th inch thick piece of under plywood. Cut it to fit, then cover it with cheap carpet material, and screw it to the door.
grs is offline   Reply With Quote
Old 05-04-2012, 06:09 PM   #9
Dalaigh
Canadian Trucker
Dalaigh's Avatar
You could always pop some rivets in the holes. It'll give you an industrial look like donut said. Or using thin ply wood build a "map" pocket for the door. And the cover it with carpet, or any kind of fabric you like.
2020 Silverado Trail Boss - 6.2/10spd
Dalaigh is offline   Reply With Quote
Old 05-04-2012, 07:24 PM   #10
kylep
kylep's Avatar
i think i am going to go the wood route and carpet it. thanks for the ideas guys i am completely redoing my interior and i am having real fun trying to stay withing a budget of paitning the car, doing the interior completely over, without spending more than 200! that is my goal!
2001 Tahoe
1978 K30
Old 05-04-2012, 07:55 PM   #11
Gordonr1973
Home Built '87
Gordonr1973's Avatar
I saw this a while ago:
http://67-72chevytrucks.com/vboard/s...d.php?t=369713
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
