Inline Six Parts for sale
Not going to be reusing the six cylinder. Selling everything off. I’ll be posting pictures shortly.
Power steering pump and brackets $100 + shipping (Currently CaptainFab is first in line for this. If he passes the next to post here or PM me gets it) This was pulled off a '79 Camaro with the NON-integrated head 250. I planned on using a double groove harmonic balancer (for a ’79 Camaro 250 – they are available new for @ $60) and a double groove water pump pulley for the same vehicle. You’d also need to use the ’79 Camaro 250 water pump. BRAND NEW IN THE BOX (NEVER USED) Skip White Performance HEI for the 194/230/250/292 Complete with cap, rotor, coil etc $60 + shipping ’65 Chevy C10 Custom Cab Aluminum Grille $180+ shipping This thing was almost perfect. I decided to strip the anodizing, as it was clouded in a couple of spots. I planned on sanding / polishing it out. I’ve completed a good bit, and it needs a couple of small dings worked out. Simply haven’t had time to work on it. I’ll take pics how it sits. If no takers, I’ll make time to finish it up and of course the price will reflect that. All engine parts are from a ’65 C10 230, unless otherwise noted: Oil Pan VGC $25 + shipping Valve cover VGC $25 + shipping Alternator (was working /charging fine before I tore down the truck) $25 + shipping OEM metal fuel lines from carb to fuel pump $15 + shipping Original 230 carb (ran fine – I’m sure it could use a rebuild) $45 + shipping Intake manifold $40 + shipping Cylinder head COMPLETE (again ran fine 150K miles) $50 + shipping Set of 6 rods in good shape w/ stock pistons still attached (one piston has a cracked spot on the lower ring land) $30 + shipping Crankshaft (needs polishing – journals measured good) $50 + shipping Flywheel (3 speed manual) in very good shape $40 + shipping Used pressure plate and clutch. Worked fine. $30 + shipping Manual transmission bellhousing in VGC $40 + shipping 3 speed manual transmission, worked fine $75 + shipping Timing Cover VGC (it’s been cleaned and pretty much stripped) $20 + shipping Pushrod covers $15 + shipping I’ve got the entire valvetrain (lifters, rockers, pushrods) all in good used shape, all bagged with cylinder number if someone needs some spares. Make me an offer ’65 230 block – cleaned, degreased, broke the honed the cylinder with a deglazer (stone type) $50 + the ride.
____________________________ |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: Inline Six Parts for sale
Payment sent for the PS pump and brackets.
I'll take the grill pending pics.
I could use the fuel line...... do you have pics? also shipping to 74464
1965 long bed ( grandpas old truck ) 1964 long bed BBW Custom Cab 1966 Short stepside 1964 long bed 1965 long bed Custom Cab, factory air, V-8, powerglide |
How much shipping on the HEI to 85205? Thanks
Lovin' my 64 GMC Fleetside Daily Driver |
![]() Join Date: Apr 2001
second in line on the HEI....
--Mike
63 C20 2WD, 230/SM420/4.11 73K 68 C30 dump truck, 327,SM425,4.56 66K original 68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes 68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79 69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi... 70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP 72 Chevy K20 4x4 350/350/205/4.56 donor 72 Vette 350/M21/3.70 posi, triple black and super fast 84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's |
#6 | |
I'll get the grille out, clean it off and take pics and post them as well.
$70 shipped via USPS parcel post.
I have a ball game to attend this evening, but I hope to get pics of all the parts up in the next day or so. Bear with me, I got really slammed over the weekend and it wasn't expected.
I will take the HEI. Please pm me payment info and I will get it out to you. Thanks!
Payment for HEI sent via paypal 5/7/12. Please advise on status of shipping. Thanks!
#11 | |
Again, I apologize for any convenience. I also want to apologize to any potential buyers, I haven't even had a chance to take pics of the other parts.
#12 | |
Sorry for any inconvenience.
#13 | |
60-66 Nut
Not a big deal for me, I'm not waiting on them. I know about being busy, I work 70-75 hours a week. I appreciate you letting us know what the status is. I'm not sure if that pump and brackets will fit into a large flat rate box or not. That would save you having to buy a box.
#14 |
I am good here too. Appreciate the response. We gotta keep working to support our "habit," right?
#15 | |
#16 | |
HEI Shipped today USPS. PM coming with tracking #. Thanks.
#17 |
Received HEI as promised. Thank you!
#18 |
60-66 Nut
I received the power steering pump and brackets today also.
Thanks again ![]()
