Inline Six Parts for sale
Not going to be reusing the six cylinder. Selling everything off. I’ll be posting pictures shortly.
Power steering pump and brackets $100 + shipping (Currently CaptainFab is first in line for this. If he passes the next to post here or PM me gets it) This was pulled off a '79 Camaro with the NON-integrated head 250. I planned on using a double groove harmonic balancer (for a ’79 Camaro 250 – they are available new for @ $60) and a double groove water pump pulley for the same vehicle. You’d also need to use the ’79 Camaro 250 water pump. BRAND NEW IN THE BOX (NEVER USED) Skip White Performance HEI for the 194/230/250/292 Complete with cap, rotor, coil etc $60 + shipping ’65 Chevy C10 Custom Cab Aluminum Grille $180+ shipping This thing was almost perfect. I decided to strip the anodizing, as it was clouded in a couple of spots. I planned on sanding / polishing it out. I’ve completed a good bit, and it needs a couple of small dings worked out. Simply haven’t had time to work on it. I’ll take pics how it sits. If no takers, I’ll make time to finish it up and of course the price will reflect that. All engine parts are from a ’65 C10 230, unless otherwise noted: Oil Pan VGC $25 + shipping Valve cover VGC $25 + shipping Alternator (was working /charging fine before I tore down the truck) $25 + shipping OEM metal fuel lines from carb to fuel pump $15 + shipping Original 230 carb (ran fine – I’m sure it could use a rebuild) $45 + shipping Intake manifold $40 + shipping Cylinder head COMPLETE (again ran fine 150K miles) $50 + shipping Set of 6 rods in good shape w/ stock pistons still attached (one piston has a cracked spot on the lower ring land) $30 + shipping Crankshaft (needs polishing – journals measured good) $50 + shipping Flywheel (3 speed manual) in very good shape $40 + shipping Used pressure plate and clutch. Worked fine. $30 + shipping Manual transmission bellhousing in VGC $40 + shipping 3 speed manual transmission, worked fine $75 + shipping Timing Cover VGC (it’s been cleaned and pretty much stripped) $20 + shipping Pushrod covers $15 + shipping I’ve got the entire valvetrain (lifters, rockers, pushrods) all in good used shape, all bagged with cylinder number if someone needs some spares. Make me an offer ’65 230 block – cleaned, degreased, broke the honed the cylinder with a deglazer (stone type) $50 + the ride.
____________________________ |
CAN'T FIX NOTHIN
Re: Inline Six Parts for sale
sent a pm on the 230 cylinder head looks like im first on it !
1967 C10 Shortbed Fleetside Small back glass 6 cyl 3spd on the tree 3.08 gears underdash AC |
CAN'T FIX NOTHIN
I want the carb too
![]() Join Date: Aug 2008
I am interested in the power steering pending photos.
Posted via Mobile Device |
425hp409
![]() Join Date: Oct 2008
Do you have an original GM harmonic balancer, double groove, for a 250 6 cyl?
Charles 68 SWB, Dad bought new, now 396 & factory ac 64 Impala SS, 409 425HP, 4 speed AC 64 Bel Air Wagon, 400 Small Block 57 Bel Air all original 283 w/Factory Air 77 GMC Sprint, 454/425HP 67 Olds 442, all original 90 ZR1 Corvette |
Im gonna get inline....no pun intended
I guess you havent been here in a while!
