05-04-2012, 01:32 PM | #1 |
Opinions needed ECE Drop 2/4 or 4/6
Im in the market for an ECE kit. Im debating on whether to do a 2.5 spindle up front with a and 4" coil drop in the rear or a 4/6
Here is a pic of my rear. Sorry I dont have the front as the entire front clip is off the truck. This is how the truck sits now. To my knowledge and im the 3rd owner after my dad handed it down, this hasnt been lowered at all. My guess is age old sagging as the truck sits somewhat level across it. Tires are 235/75/15 with 6.5 rally's. Anyone running the same size tired and the listed drops above? I have done several searches and cant really make up my mind. |
05-04-2012, 01:34 PM | #2 |
C/10 junkie
Re: Opinions needed ECE Drop 2/4 or 4/6
4/6 all the way, in the end I think you will be much happier.
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" |
05-04-2012, 01:36 PM | #3 |
C/10 junkie
This is about a 5/7 drop.
05-04-2012, 01:48 PM | #4 |
I have a 4/6 i love it.
05-04-2012, 01:54 PM | #5 |
Are you guys replying have roughly the same size tires?
I want to be able to drive it, however I dont want a "slammed" look per say. Missouri roads arent the greatest so if im too low, gonna have problems. Another concern is long tube headers. 4/6 clear without any issues? |
05-04-2012, 02:02 PM | #6 |
Frequent Flyer
235/70/15's on 4/6 drop
05-04-2012, 02:09 PM | #7 |
Trucks are looking great!
Jwall, what size rims are you running on those? Did you have to shave off your A-Arm? You running ECE Spindles as well? |
05-04-2012, 02:22 PM | #8 |
4/6 will do the trick, 2/4 will leave you wanting to lower more...
'69 Fleet It ain't yours, if you didn't build it! |
05-04-2012, 02:29 PM | #9 |
///Relaxed Atmosphere
4/6 has my vote and like stated above i want lower now
71-Cheyenne Super (E.C.E Static Drop 4.5/7". Intro Rally's 20X8.5 5" B.S 255/35/20 (F) 20X10 5.25 B.S 275/35/20 (R) 87-Silverado Static Drop 5/7" Raceline Explosion 5 22X8.5 (F) 22X10 (R) hector _________________________________ 1971 Chevrolet Cheyenne Super 1987 Chevrolet Silverado 2006 Ford Mustang GT 2012 Toyota 4-Runner 2014 Dodge Ram 1500 Sport Crew Cab |
05-04-2012, 03:46 PM | #10 | |
Frequent Flyer
I did trim the lower A-Arm. Yes, I used all ECE parts. That truck was 2/4 dropped when I got it & it just wasnt low enough. |
05-04-2012, 04:33 PM | #11 |
2/4 is not nearly low enough and you will want more.. 4/6 is the way to go...
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
05-04-2012, 05:04 PM | #12 |
Shawn -- is your white truck notched at 5/7? How low can I take the GMC without a notch? I don't haul much of anything and I'm putting new wood in it soon, new strips, etc. So, I just won't be hauling refrigerators or anything. Is there any room left at all on a 7? Would you do 5" springs, 2" blocks? or 6/1 ? Are you guys running pinion shims at 6 / 7" rear drop?
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
05-04-2012, 06:40 PM | #13 |
I'm running something similar to the 2/4 drop you are considering, all ECE suspension components.
Front = 2.5" drop spindle + 1" lowering spring, 225/75/15 on 15x6.5 Rear = 4" drop springs, shock relocators, super track bar, 255/70/15 on 15x8
66 GMC Suburban Custom 66 Chevy K10 Suburban Last edited by Southcity; 05-04-2012 at 06:51 PM. |
05-04-2012, 07:09 PM | #14 | |
C/10 junkie
05-04-2012, 07:11 PM | #15 |
C/10 junkie
Here is a couple more angles.
08-07-2015, 07:41 PM | #16 | |
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
08-07-2015, 10:54 PM | #17 |
Here's mine 4.5/6. 2.5 drop spindles. Little too low in the front. I'm going to put in 1in springs instead of the 2in shown.
08-07-2015, 11:01 PM | #18 |
Side view. Doesn't look too bad
08-08-2015, 12:30 AM | #19 |
That looks beautiful Jcfcamaro........I can see why you'd want to lift a tad in front. Either way looks great.
08-08-2015, 03:02 AM | #20 |
Fwiw the roads up here are pretty bad, so I asked a local vendor (scotts super trucks) what I should buy and not have any issues with bottoming etc and they suggested 2-4 drop.
"You can take the man out of PA, but you can't take PA out of the man" |
01-06-2018, 03:01 PM | #21 |
With the 4/6 drop did any of you have to alter the trailing arms or mounts any wat to get the right angles for rear end so no vibration
OLDIRONRACING |
