Old 05-04-2012, 04:20 PM   #1
crewcabsquared
Crew Cab Headliner Question
I have a 86 K30 crew. It currently has the inner steel panels screwed and spot welded to the roof in place of a headliner board. I have all the moldings and a board to put in a fabric headliner, and would really like to.
Questions:
1. Can I remove the steel liners and install the board/moldings, or am I going to screw up the roof braces? I have spotweld drillbits and all. I would like to go this route so I can attach some fatmat or dynamat to the roof underside to help with insulation.
2. If not has anyone adhered the headliner material straight to the metal panels and installed the moldings? I have the headliner material and adhesive and plenty of experience installing h-liners.
Thanks in advance for any input!
crewcabsquared is offline   Reply With Quote
Old 05-04-2012, 08:01 PM   #2
ozark
Re: Crew Cab Headliner Question
I'm confused. My 88 the headliner boad went up against the inner steel panel of the roof, it was not open like a suburban. Are 86 crew cabs different?
Never mind I reread and now understand
I wouldn't cut the panels out.
ozark is offline   Reply With Quote
Old 05-04-2012, 09:16 PM   #3
crewcabsquared
This is my first time adding a headliner to one of my crews, all of them have had the steel interior panels (custom deluxes) I was thinking that the Silverado's were like high end Suburbans that do not have the steel painted inner roof, the headliner board goes up against the roof braces and is held up with the perimeter moldings. The spotwelds and screws are where the roof braces are I believe. Did your headliner board go over the steel panels? Looks like it would make the board to low?
Old 05-04-2012, 09:19 PM   #4
ozark
My 88 was a silverado and it had the inner roof panels the headliner went up against it.
Old 05-04-2012, 09:35 PM   #5
bilfman
bilfman's Avatar
My buddy and I just did headliners twice. His had a bare metal roof and my headliner was a mass of rotted fabric. We just cleaned up the old moulded headliner and glued new fabric to it, it turned out great. For his we found an old beat headliner from a wrecker, cleaned it up glued some fabric and put it in his truck. I assume the previous owner threw out your old headliner if you have all the trim strips.
Ez mode to glue it down is to set it up on some saw horses, lay your fabric on on the headliner. Fold half the fabric back over itself. Spray the exposed half of the headliner and the folded fabric. Pull it over onto the glue and press together, repeat same proceedure for the other half. The one in the pics cost a total of $42 including the adhesive.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205
1971 GMC 3/4 Ton 4X4
bilfman is offline   Reply With Quote
Old 05-04-2012, 10:21 PM   #6
cochino12
It followed me home?
cochino12's Avatar
How did you get it out of the truck? Seems like it would be tough getting it out without messing it up
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 05-04-2012, 10:36 PM   #7
esbstuff
It is possible, but windshied removal is required not to damage or crease it...
esbstuff is offline   Reply With Quote
Old 05-04-2012, 11:31 PM   #8
crewcabsquared
Ok, thanks for the info. I didnt know the crew headliner board would go over the inner roof panels. I've got the board and material and have done plenty of h-liners. I guess seeing the suburbans with no inner panels under the board just had me worried. Guess i've got my plans for the weekend!
Again, thanks, that's what makes this the best forum I've been on.
Old 05-05-2012, 09:56 PM   #9
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Or you can pull the front and rear seats. Then with a bit of careful wrangeling get the headliner twisted and pulled out the rear doors without damaging it.
Done that a couple times inna past.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 05-06-2012, 03:30 PM   #10
SCOTI
SCOTI's Avatar
I've been wondering this as well. I was hoping the glass didn't have to come out. Sounds like if you're doing the whole interior & the seats are out anyway, it's worth a shot trying to 'wrangle' it out.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-07-2012, 12:53 PM   #11
mikev
mikev's Avatar
What's the best way to source a headliner board?
mikev is offline   Reply With Quote
Old 05-07-2012, 01:52 PM   #12
bilfman
bilfman's Avatar
We got ours in and out through the passenger front door, wasnt a big issue.
Old 05-07-2012, 02:12 PM   #13
crewcabsquared
Thats where I am, can't find a board(thought I had one found but no luck after all). They make them for suburbans, blazers, and pickups, but no crew cab everywhere I have looked. I have heard you can splice together the front 3/4 of a suburban board and the back part of a pickup board.
Old 05-07-2012, 02:38 PM   #14
Jonboy
Slots go on anything!
I was thinking the driver's rear door would be the easiest, since you will be going out the direction the door is pointing.
1974 Jimmy- 5.3/4L80e/NP241
Old 05-07-2012, 08:48 PM   #15
bilfman
bilfman's Avatar
Well having actually doing it 3 times in the past 4 months I can tell you the passenger front door is the only one it will go out without damage. It totally helps to have 2 people to do it. One helping from the drivers side and the other working outside the passenger door.
I did find a crew cab headliner supplier after a bit of a google search but it was $475.00 ish. Way too pricy for my liking. Our reglued units turned out as good as new for $50ish. My buddy bought the actual foam/cloth headliner material. He ordered a piece from a local fabric place. It was about $50. I just bought some dark blue stuff that looked 'headlinerish' for $30 both turned out great.
Old 05-07-2012, 10:34 PM   #16
yousesteers
I need a board and am getting ready to swap my back window for asliderwould it fit through the back window.
Clint Youse
Paris, MO
1984 Chevrolet 3+3 K30 with Cummins
1966 IH Scout has been a work in progress for 16 yrs
yousesteers is offline   Reply With Quote
Old 05-08-2012, 08:34 AM   #17
crewcabsquared
Scored yesterday . On my way home I spotted a crew cab dually in the weeds behind a paving shop. Stopped and got ahold of the owner. Long story short, he let me take anything I wanted off of it for $100.00! Got h-liner board, some more interior moldings, dome lite and wiring, sill plates, cargo lite and wiring, super nice 3+3 emblems, and a good cab band w/clips.
Old 05-08-2012, 10:49 AM   #18
mikev
mikev's Avatar
Holy crap, that's awesome!
Take measurements of the headliner board!!!!
Did it have power windows/locks? I'll pay ya to get em and the wiring harnesses for me
Old 05-08-2012, 01:24 PM   #19
crewcabsquared
I may try to make a mold from this one. And no luck on the power windows/locks. But we have a pic a part locally that has 5-6 suburbans with them. I think I am going to leave mine manual, less headaches!
Old 05-18-2012, 04:22 PM   #20
Stew_Magoo
What did you do to prep the old headliner board? Was it that molded insulation looking ****?
Stew_Magoo is offline   Reply With Quote
Old 07-26-2012, 06:18 AM   #21
mckustomfab
Been lurking on this board for a while (lot of great info) but thought i would add something i found for the headliners. I think im going to go this route, the price is not outrageous and i'm having a hard time finding a board that's not just shot. http://www.classictruck.com/product/...n_Kits_Crewcab
mckustomfab is offline   Reply With Quote
Old 07-26-2012, 09:39 AM   #22
crewcabsquared
I looked at those, I think they are held up by bows like an older car headliner. Might be a good alternative for you though. When I called and asked them about the kit, they informed me of the bow installation.
Old 07-26-2012, 11:47 AM   #23
LOW1TON
When I redid mine I just pulled out the back window. Took about 5 minutes, pulled headliner, glued new suede on and reinstalled it followed by reinstalling back glass, only took about an hour and a half to do. No seat removal required.
"WIDER IS BETTER" (TRUCKS ONLY)
LOW1TON is offline   Reply With Quote
Old 07-26-2012, 12:34 PM   #24
mckustomfab
Well that's some good info on the bow style head liner, saved me some trouble. I guess the search continues for a headliner.
Old 11-05-2012, 10:13 AM   #25
carboncrew
carboncrew's Avatar
Does anyone know if the crew cab headliners and headliner trim are the same from 73-91? Or did things change in 81 etc...?? Thanks
carboncrew is offline   Reply With Quote
