Old 05-04-2012, 06:39 PM   #1
tjpresley1978
Drop a '67 SWB Advice
I would like to lower my '67 because it's way too high. I really like the look of the 4/6 drop - but I'm trying not to break the bank. It's got drum brakes and 6 lug pattern on there now. From what I've gathered - to go with a 4/6 drop - you have to put drop spindles on the front - upgrade to disc brakes - c-notch the rear frame - relocate the shock mounts - get an adjustable sway bar, along with drop coils, etc., etc. I'd also have to change the wheels to match the 5 lug rotors - which I plan on someday anyways. It's just looking like it's going to cost alot of money to lower the truck 4/6 inches.
Is the lowest I can go just swapping the coils out 2/4?
tjpresley1978 is offline   Reply With Quote
Old 05-04-2012, 06:46 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Drop a '67 SWB Advice
You can do a 3/5 with just coils.
But you really need drop shocks, rear shock relocators and an adjustable track bar.
Keith
Convert to disc brakes.
Old 05-04-2012, 07:14 PM   #3
Pro Performance
Pro Performance's Avatar
Here is a Hotchkis 4/6 kit we sell, and when you add Belltech shocks, it is $529. The adjustable trac bar is a good idea when dropping low in the rear. It will help re-center that axle. I would definitely do the shorter shocks.
http://www.azproperformance.com/Hotc...390-19392.html
Pro Performance is offline   Reply With Quote
Old 05-04-2012, 09:09 PM   #4
tjpresley1978
Thanks!
Old 05-04-2012, 09:10 PM   #5
tjpresley1978
I can put these drop springs and shocks in without having to change the spindles and c-notch the frame? I would go with the drop shocks and would need shock relocators and an adjustable track bar - but I wouldn't need to do any other mods? That would be awesome if that's the case!
Old 05-04-2012, 09:17 PM   #6
VA72C10
VA72C10
VA72C10's Avatar
I've heard many with issues with getting alignment correct with 3" coils...can't imagine with 4" coils....first I've seen anyone offer that...
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 05-04-2012, 10:18 PM   #7
Pro Performance
From my discussions with Hotchkis, you won't need anything else. Like the other guys said, an adjustable trac bar is a good idea to have. That can always be added later.
I asked Hotchkis about the the alignment issues, and they claim you will not have any problems. It is a big drop for the front, but Hotchkis is known for quality suspension. I don't think they would offer a kit that would cause issues. I do recommend drop spindles and a 2" spring, but that isn't always in everyones budget.
Keep in mind, the 6" rear drop is from factory height. It is common that after "x" years, the stock springs have sagged some.
Old 05-05-2012, 12:30 AM   #8
thelonerife
thelonerife's Avatar
i would do the ECE 4/6 drop kit and be done with it. I think it was 700.00
Heres mine with it. Its some work but If I had to do it again I would get the same kit.
thelonerife is offline   Reply With Quote
Old 05-05-2012, 11:53 AM   #9
tjpresley1978
Thanks. Did you have to use drop spindles and c notch the rear? Do you have the adjustable track arm as well?
