Help with a 67 GMC VIN needed
Hello all,
Purchasing a 67 GMC stepside, and the VIN decoders I have seen on here confuse me because the VIN on the truck doesn't fully match the examples i found on this site. My VIN is CS1570C PC9001A Any help appreciated. Kind regards,
My build thread... http://67-72chevytrucks.com/vboard/s...d.php?t=515829 Disabled Veteran 82nd Airborne Division Operations: Desert Shield, Desert Storm, and Uphold Democracy |
Re: Help with a 67 GMC VIN needed
The 15 is for 1/2t. The 70 stumps me. That should be a letters. The digit where the 7 is would denote body type,such as Fenderside (C) or Wideside (D). The next digit would denote the assembly plant and there's no plant I know of that zero or the letter O is used for. C is for 1967.
Are you reading this from the VIN plate on the door jamb?
Yes, when you open the door, on the right hand side door jamb is the plate
I will reverify the number, but i'm pretty sure that it is correct.
C= 2wd
S= straight 6 1= 1/2 ton 57= 115 inch wheelbase OC= stepside P= pontiac assy. plant C= 1967 9001= build # A= GVW less than 6000
CHEVY/GMC VIN DECODERS |
bruceman, thank you for giving me the info! I hope this is a good truck.
How can I tell what size 6 cylinder is in it? Kind regards,
#6 | |
Sierra Grande Club
![]() ![]() Posted via Mobile Device
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() |
![]() Join Date: Dec 1999
It is a 250 six cylinder if noone has changed it out in the past
Original paint color "Palomino Tan" .
