I'm at the swap meet here in Canfield Ohio and have came across two different sets of valve covers that I like and have a question because my truck is not here to check.......The covers I want are the aluminum welded comp covers that are 1/8" thick on the bottom and my issue is....they have a short pair that needs the oil fill hole and the breather hole in the other one cut out and they do not have a baffel obviously. The tall pair has a baffle and both oil and breather holes are present. My truck is a 1972 chevy 1/2 ton with the factory 402 with the ridiculous drum brakes for now at all 4 corners. (whole nother story why there not disc in front) and I dont know if i will have clearance issues with anything if I get the Tall covers that I really want. Any help soon would be appreciated. Thanks
Re: Big Block valve covers....
I use the small booster on my trucks and i have tall v/c on them,,, im a little confused though cause all trucks 71 and later had disc in the front,,,if u do have a 69 truck then there is a good chance u have the smaller booster,,I think they r 9" verses the 11"
67 chevy short step 2wd 427 71 chevy short fleet 4x4 396 72 gmc jimmy 2wd 377 71 chevy blazer 4x4 454 69 chevy longhorn 5.9l cummins 72 chevy 400 2wd custom camper 67 chevy lwb 4x4 454-in pieces 67 chevy panel soon 4x4-400 67 gmc dump 4x4 1 ton-305 WTF!! 72 chevy 3/4 ton 4x4 burb 350 70 chevy panel 2wd 302 5 speed tko "THERE IS NO REPLACMENT FOR DISPLACMENT"!!!!!!! |
