Old 05-05-2012, 01:08 PM   #1
Jhogan63
Jhogan63's Avatar
Ididit install help
I am installing an ididit tilt column in my '63 using the stock bracket but the ididit column doesn't have any mounting holes? They claim it installs using stock hardware? Any help would be appreciated.
Jhogan63 is offline   Reply With Quote
Old 05-05-2012, 02:26 PM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: Ididit install help
Yeah, it's a little misleading...you do use the lower bracket that the parking brake handle mounts to, but you'll need to secure the column with a couple of sheetmetal screws where the orginal two bolts were located. Then you have to use one of the interior firewall column mounts where it passes through the opening in the firewall. I used a stainless T-bolt clamp on the otherside of the firewall securing the column to the factory flange. I hope that helps a little.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 05-05-2012, 03:08 PM   #3
Jhogan63
Jhogan63's Avatar
Thanks Vin63. Would it be possible to send me some pics of how to mounted yours?
Old 05-05-2012, 08:34 PM   #4
vin63
vin63's Avatar
I don't have any photos right now, and my truck is apart...I'm prepping the cab for paint. But, if you go to the Ididit site and the tech area, there are instructions for the Tri 5 installation, which is similar to the installation process that I used.
Old 05-05-2012, 08:46 PM   #5
Jhogan63
Jhogan63's Avatar
Thanks for the help Vin63
Old 05-06-2012, 03:44 AM   #6
Rob Fisher
I installed an Ididit column into my 64 GMC recently but not before I sent it back to Ididit to have them update it to their latest version. The new version includes threaded nuts that slide in slots on the column allowing you to bolt it to the park brake bracket. No drilling required.
Rob Fisher is offline   Reply With Quote
Old 05-06-2012, 09:31 AM   #7
Jhogan63
Jhogan63's Avatar
Why wouldn't I get the updated version it showed up to my house Friday? It was on back order for 2 months an just built it last week.
Old 05-06-2012, 11:53 AM   #8
Rob Fisher
I had the same problem that you did, no mounting holes or nuts to mount to the stock park brake. I spoke to them at their booth at the SEMA show and they said send it back and they will update it. I did that nearly a year and a half ago. It came back with 2 slots about 3" long running the length of the column near the top where the bracket would bolt on. In behind the slot was a plate with 2 threaded holes that could slide up and down to line up with the holes in the stock bracket with the stock size bolts. They took the column back and updated it at no charge. I would give them a call. Better then drilling holes in your new column. You might also want to double check for length, I had to end up getting mine shortened a couple of inches because I swithched to rack and pinion steering and these columns were designed to work with the stock steering.
Call them, they had no problem helping me out.
I spoke to Marty Waterstraut, Ididit Sales manager, (517) 424-0577
My Part Number was 1140650010.
Old 05-06-2012, 12:02 PM   #9
Jhogan63
Jhogan63's Avatar
Thanks for the help Rob. I talked to Marty last week so I'll let him know what's going on.
Old 05-06-2012, 07:19 PM   #10
gimmy 64
my column from ididit was one you had to drill holes to mount it but i thought it was okay because i put down as far as i could so i would have more room. it's not that big of a deal drill holes for screws and put locktite on them. its not going anywhere
gimmy 64 is offline   Reply With Quote
Old 05-06-2012, 07:47 PM   #11
Jhogan63
Jhogan63's Avatar
Thanks Gimmy64. Did you drill and tap or use sheet metal
Screws? Mine is brushed aluminum so I want to make sure it will hold.
Old 05-06-2012, 11:35 PM   #12
doobiebro
doobiebro's Avatar
Jhogan63 mine was not a ididit column but they all look the same. Mine cost $199.00 on EBAY shipped. Using the lower firewall mounting clamp and upper park brake lever bracket assy the column mounted solid. I did use a 5/8 rubber hose I cut out to stick in between the lower dash and top of the column to mount tight. Its not really necessary to mount screws but the vendors recommend. I bought 2 aluminum thread serts 1/4'' - 20 thread. I marked the holes and held the column in position with a bucket and 2x4. Removed the park brake lever mount and drilled the 2 holes (do not oversize the holes) push in the thread serts (make sure it goes in tight) and crimp with a special tool. I used a long 1/4 bolt with nut and tighten insert while it sqeezes tight like a rivet. It now looks like the column came with mounting bolts. Also when you drill the column tube there is about an 1" to 1 1/2" between the outer tube and inner pipe...
CURRENT & PAST CHEVY TRUCKS
60 C-10 Apache short step side
62 C-10 short step side
66 GMC Long bed fleet side 305 V-6
77 C-20 Custom Deluxe (Blue Goose)
doobiebro is offline   Reply With Quote
Old 05-07-2012, 08:54 AM   #13
66farmer
66farmer's Avatar
What did you guys use for the firewall bracket, any pictures
66farmer is offline   Reply With Quote
Old 05-08-2012, 12:55 PM   #14
doobiebro
doobiebro's Avatar
Used the stock lower firewall bracket clamp assy as long as the steering column tube is 2" diameter. Also ordered a new seal for the firewall cover...
Old 05-08-2012, 01:30 PM   #15
Jhogan63
Jhogan63's Avatar
Thanks for all the help guys. I talked to Ididit and they said they have updated the steel columns to have a slot with nuts in them but the aluminum columns don't because they are thicker and not room to do it. I'll post pictures when it's installed.
Old 05-08-2012, 01:55 PM   #16
1963c-10
1963c-10's Avatar
Doobiebro...did you chrome plate the ebrake or polish it out?
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 05-08-2012, 02:16 PM   #17
doobiebro
doobiebro's Avatar
1963c-10 I sand blasted the ebrake assy and sprayed it with a rattle can chrome paint (rustolem)..
Old 05-08-2012, 07:18 PM   #18
gimmy 64
on the support for the column you use sheet metal screws and i just used the stock column support on the outside of fire wall. mines 64 and i used thread lock on the sheetmetal screws
Old 05-09-2012, 03:06 PM   #19
1963c-10
1963c-10's Avatar
Looks damn good to me.
Old 08-16-2016, 07:26 AM   #20
thunder71
thunder71's Avatar
I just installed mine and drilled and taped the holes and used original bolts...my column came out of my 68c10 along with the power steering box...
_____________________________________
66 C10 shortbed stepside KEEPER
66 C10 longbed stepside SOLD
69 C10 shortbed stepside SOLD
71 C10 custom deluxe long fleetside SOLD
thunder71 is offline   Reply With Quote
Old 08-16-2016, 01:17 PM   #21
The1960APE
The1960APE's Avatar
I've used IDIDIT and Flaming river columns in various projects. I personally wont use another IDIDIT.
The Flaming River column used in my 61 Apache build was a direct bolt up and fit very securely! Their shaft design is a much stronger and safer setup than the IDIDIT columns I have used in the past where they require you to cut your old steering shaft, grind it and use a set screw, I have seen those fail and come loose, that scares the crap out of me!
1965 Olds 442 "Project Oldmobile"
1971 2wd GMC Jimmy..."The Orangutan"
1961 Apache "The Ape"
http://67-72chevytrucks.com/vboard/s...d.php?t=679735
The1960APE is offline   Reply With Quote
