Old 05-05-2012, 03:05 PM   #1
theastronaut
theastronaut's Avatar
Need pics of 230/250 engine mounts
I'm about to start mocking up the engine and transmission in my '66 and I'm starting from scratch with nothing to go by. I bought it as an unfinished project so I didn't have the privilage of taking it apart myself. It's a bare frame, and I've got a 250 engine block, and a T56 six speed. I've got perches and new motor mounts, but I'm not sure what set of holes to use on the frame rails or crossmember for the perches. It looks like it only goes together one way, but I want to make sure before I make my transmission crossmember for the T56. I was thinking that an inline 6 used the foward set of holes on the frame rails, but the perches I have only line up with the rear set of holes. The guy I bought it from was going to put a V8 in it, so maybe I have V8 perches? Or are they the same as an I6? Any help would be greatly appreciated!
theastronaut is offline   Reply With Quote
Old 05-05-2012, 03:22 PM   #2
padresag
Re: Need pics of 230/250 engine mounts
those perches are all the same. the exception is the right 292.perch. i6 mount in the forward 2 holes. what doesn't line up with them?. perhaps a picture from you showing us. perhaps those are not the right perches-different years
ron
padresag is offline   Reply With Quote
Old 05-05-2012, 04:25 PM   #3
theastronaut
Here's what I've got. Disregard the extra holes that have been drilled, the PO did that before I bought it.
Left picture is the driver side, right picture is the passenger side.
These two pics show the holes in the crossmember and frame rails.
These two show the perches aligned with the rear holes.
These two show the perches alignes with the front holes, but nowhere to mount the bottom holes on the crossmember. I can drill holes, but since it had a 250 from the factory, shouldn't there be holes here?
Old 05-05-2012, 04:29 PM   #4
sigshooter
sigshooter's Avatar
Gonna go snap some pics of mine in the driveway..... be right back
1965 long bed ( grandpas old truck )
1964 long bed BBW Custom Cab
1966 Short stepside
1964 long bed
1965 long bed Custom Cab, factory air, V-8, powerglide
sigshooter is offline   Reply With Quote
Old 05-05-2012, 04:41 PM   #5
sigshooter
sigshooter's Avatar
here is mine looks like the second set of your pics is correct
exhaust on drive side
fuel pump on pass side on my pics
1966 Short stepside
1964 long bed
Old 05-05-2012, 05:00 PM   #6
theastronaut
Thanks Sig!! I was thinking that inline 6's used the front set of holes for some reason, that's where the confusion came from.
Old 05-05-2012, 05:15 PM   #7
padresag
had to go out and look at my 1t. they are in the rear holes
ron
Old 05-05-2012, 05:53 PM   #8
theastronaut
ron
Thanks Ron, I did some digging around and found a pic of the '65 I redid before I took the engine out, and it was also in the rear holes.
Old 05-05-2012, 10:48 PM   #9
theastronaut
Got everything mounted up, thanks again guys!
Old 10-03-2019, 11:39 AM   #10
jaxncurtis
Anybody know where I could buy some new or good shape used perchs and mounts for my Chevy 250 engine?
1970 Chevy K5 Blazer
jaxncurtis is offline   Reply With Quote
Old 10-05-2019, 12:05 PM   #11
old51sedan
old51sedan's Avatar
I have a set from my 250 I just pulled from my 69 C/10 As far as I know there the same as the blazer, put not positive.
old51sedan is offline   Reply With Quote
Old 10-05-2019, 05:28 PM   #12
jaxncurtis
They have to be better than the ones I pulled off my blazer. How much will it cost to take them off your hands.
Old 10-06-2019, 11:21 AM   #13
old51sedan
old51sedan's Avatar
Hows 40.00 plus shipping, if interested I'll post pictures for you.
