Old 05-06-2012, 09:18 AM   #1
SS317
SS317's Avatar
66 rear bag question
I have a stock 66 long bed. I tow my landscaping trailer around all day, daily driver. The stock springs are pretty much done. I've been looking at the D2600 bags for the rear but in the searches I've done I can't clarify if I need brackets or not. I've searched a few site vendors and can't find a specific application for the 66. I already have air shocks in the rear.
I just want a set up I can air up with my shop air if needed.
Is it better to spend the 400 bucks for a kit from ridetech and have it done?
Thanks.
1966 Chevy C-10
350 Engine
700R4
SS317 is offline   Reply With Quote
Old 05-06-2012, 10:15 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: 66 rear bag question
You can mount the bag directly to the trailing arm and the frame.
You will have to drill 2 mounting holes in the frame,... and a larger hole for the air fitting.
The trailing arm bolt will need to be a 3/8"x4" bolt with a large heavy washer under the bolt head.
I would just run to separate lines to the rear of the truck and instal schraders on them for easy fill with your shop air.
Keith
Convert to disc brakes.
Old 05-06-2012, 03:11 PM   #3
SS317
SS317's Avatar
Thanks for the reply. That sounds really easy and cost effective!! I appreciate it!
I lived in Columbia for a year two years ago and drove over to Fulton to see the airport. Great area!
1966 Chevy C-10
350 Engine
700R4
Old 05-06-2012, 03:17 PM   #4
SCOTI
SCOTI's Avatar
Let me add something to consider....
If the truck is stock height & the bags are bolted directly in place w/o any 'brackets', it will likely lower the rear of the truck. The brackets would add to the overall height & might be better for an application where the truck is @ stock height.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 05-06-2012, 03:22 PM   #5
SS317
SS317's Avatar
Good point, I cannot seem to find brackets anywhere for the 66 c10. Any suggestions?
1966 Chevy C-10
350 Engine
700R4
Old 05-06-2012, 03:46 PM   #6
SCOTI
SCOTI's Avatar
Ride Tech made brackets specifically for installing bags on the rear of truck arm C-10's for their 'cool-ride' kit but didn't list them separately. I would try them.
http://www.ridetech.com/store/1963-1...ar-system.html
Early Classics also used a larger sleeve type bag in their kits @ one point in time that might work as well too so they might be another possible option.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-06-2012, 04:14 PM   #7
Pro Performance
Pro Performance's Avatar
I am thinking universal bag cups will work in this application, and I can get those for you separately.
Pro Performance is offline   Reply With Quote
Old 05-06-2012, 06:55 PM   #8
SCOTI
SCOTI's Avatar
Technically, only one is required for the top of the bag. Another nice thing about using them is it makes the install eaier (no holes to drill).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-07-2012, 02:56 PM   #9
PBFAB.COM
PBFAB.COM's Avatar
We offer a complete rear system that would include all the necessary items required to install the airbags in your truck, along with the airbags and new shocks. Since you use the truck for hauling, it's going to be best to keep the bags independent from each other so you don't end up cross loading the bags. You can use a simple shradder valve system to fill the bags independently and run the lines to a simple location that can be filled from an air source ( home compressor, on board compressor, etc. ). We can supply you with airline and fittings as well, or you can try and source them locally if you prefer.
Here's a picture of our system that retails for $349.00 as shown
The stage 1 rear kit is both an economical and easy way to lower the rear of your 63-72 C10's trailing arm suspension. The air spring and mounting plates replace the factory steel coil spring, allowing a better ride quality and adjustability! Our Stage 1 shock relocator brackets improve shock function by decreasing the shock angle!
Includes:
-Upper air spring mounting cup
-Lower air spring mounting plate
-Upper and lower shock relocator brackets
-Two Slam Specialties SS7 or SS6 air springs
-KYB shocks
-All grade 8 mounting hardware
You can also check it outline and call or email us with any questions or concerns.
http://www.porterbuiltfabrication.co...-1963-1972-349
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 05-07-2012, 03:07 PM   #10
hopped up
hopped up's Avatar
that sounds like a deal. i already have gauges and switches. hmmm...
hopped up is offline   Reply With Quote
Old 05-07-2012, 03:15 PM   #11
PBFAB.COM
PBFAB.COM's Avatar
Sounds like we're going " dutch" then since each one of us has what the other needs to complete the date. Plus I'll pay for the gas since you're driving.
It's a sweet kit and for that price it's a killer deal considering the bags and shocks are included.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 05-07-2012, 05:40 PM   #12
SS317
SS317's Avatar
Includes:
-KYB shocks
Can you PM me a price without the shocks? I already have new air shocks installed. And yes, I'd want the air line included to make it easier.
1966 Chevy C-10
350 Engine
700R4
Old 05-07-2012, 05:45 PM   #13
hopped up
hopped up's Avatar
damn!!!! im really considering this kit
Old 05-07-2012, 05:49 PM   #14
Pro Performance
Let me know as we are a Porterbuilt dealer and can help you out as well. Is there a group buy happening here?
Can't beat it for the price and comes with shocks and relocation brackets which most people often forget is needed also to do it correctly.
Old 05-07-2012, 05:52 PM   #15
SCOTI
SCOTI's Avatar
Use the shocks that come w/the kit & shelve the air-shocks. Correct gas pressured shocks add to the ride quality.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-07-2012, 06:22 PM   #16
PBFAB.COM
PBFAB.COM's Avatar
I will shoot you over a price on the kit, however I strongly recommend removing the air shocks and recommend running a standard gas shock instead. Basically you're using the air shock to help offset the sagging suspension now and you wont be needing them once you've installed the airbags. If anything, we can quote you on the system less shocks for now, and if you choose to purchase the system we can discuss shock options then. You could always install the system and then purchase a new set of shocks accordingly at a local parts store.
Let me get a PM sent over to you for the kit, less shocks.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 05-08-2012, 08:56 AM   #17
fleetman
does this kit require adjustable or relocated panhard bar ?
thanks
Includes:
-KYB shocks
fleetman is offline   Reply With Quote
Old 05-08-2012, 12:12 PM   #18
PBFAB.COM
PBFAB.COM's Avatar
You can use the factory track bar / pan hard bar with the system. It's an option if you would like to upgrade to our adjustable track bar, but not required.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 05-12-2012, 05:55 AM   #19
C-10cutty
C-10cutty's Avatar
Would this system work on my '62 fleetside?
C-10cutty is offline   Reply With Quote
Old 05-12-2012, 10:11 AM   #20
chevyrestoguy
chevyrestoguy's Avatar
I already have a Super Track Bar kit with the shock relocators, and a 5" drop rear coil. If I wanted to add a supplemental bag system to augment the suspension when I pull a trailer or a heavy load in the bed, what set-up would I use? Nathan's set-up looks like it replaces the coils with bags. I'd like to have a little of both. Springs for everyday use, bags for the heavier load.
Is there a kit that has what I'm looking for?
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 05-22-2012, 04:42 PM   #21
rusty_67
rusty_67's Avatar
I really like the look of this kit. I want to put bags in the rear of my truck for hauling/handling, but i don't want to lower it much. I want to keep the front stock height and be able to have the rear almost level with it. Would this kit work for me?
rusty_67 is offline   Reply With Quote
Old 05-22-2012, 05:39 PM   #22
Pro Performance
Yes, that Porterbuilt kit would work for you. However, I would add a cup kit (spacer) so the back of the truck does not sit as low.
Old 05-22-2012, 05:50 PM   #23
rusty_67
rusty_67's Avatar
Do I still need the shock relocators if i'm keeing a fairly stock height?
Old 05-22-2012, 06:55 PM   #24
Pro Performance
Not necessarily... PM Sent with pricing.
Old 05-26-2012, 06:05 PM   #25
SS317
SS317's Avatar
Ok, Got the kit, got it installed, waiting to see if the passenger side still leaks. I think I found the spot it was leaking but not sure.
Kit was pretty good. It didn't fit like I thought it would but it looks dam sturdy. took it on a small test drive and it felt just fine.... just have to see about the leak.
1966 Chevy C-10
350 Engine
700R4
