Old 05-06-2012, 07:09 PM   #1
danny6892002
danny6892002's Avatar
Craigslist made me do it also!!!
I got this Custom 10 for parts but i think is in better conditions than mine. Its hard to find a good parts truck here in south texas because of the humidity here next to the gulf. I got it from craigs last week for 1000 i dont know if its to much for a parts truck but i have decided to used for some time it only needs the back up lights. The engine is in very good conditions does not smoke but i dont know what engine it is only that its a sbc. It has front disk brakes and its a 3 speed trans. But i do have some questions wen i press the gas it wants to turn off but then it revs up when in neutral and all gears? also what engine will that be is has on the pass side next to the head F05I7? The oil filter is longer than the long bed it has, i have never seen a filter that long. it has a 2bbl carb with the chevy logo on it, i have the intake and cab to make it into a 4 bbl but i want to keepit the way it is. and i also think it has points. I was impressed everything works on the truck. It does have rust but not as much as mine. Any help plz.
danny6892002 is offline   Reply With Quote
Old 05-06-2012, 07:14 PM   #2
1972RedNeck
1972RedNeck's Avatar
Re: Craigslist made me do it also!!!
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 05-06-2012, 07:17 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
That looks like a pretty decent truck. I think you did OK on the price.
I'm wondering if the accelerator pump in your carb is not working. That will make it fall on it's face when you push the gas pedal down, especially when the engine is cold.
Maybe some of the other members will have some more ideas...
LockDoc
Leon
Old 05-06-2012, 07:36 PM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
Looks like an older engine with the canister type oil filter.
I bet it's actually a 283 or 327.
Check the numbers on the front of the block.
Keith
Convert to disc brakes.
Old 05-06-2012, 08:02 PM   #5
hopped up
hopped up's Avatar
Def a 283 or 327 with the oil fill on the intake and that canister oil filter
hopped up is offline   Reply With Quote
Old 05-06-2012, 08:13 PM   #6
danny6892002
Well I bought it as a 307 or a 350 according to the PO which he had seen this truck 2 times.
are parts like spark plugs, distributor, oil filter, etc the same for all SBC
Old 05-06-2012, 08:20 PM   #7
jocko
jocko's Avatar
if it's a 307 or 350, someone went to a lot of odd work to make it look a lot like a 327/283 with older tech on it. Odds are seller didn't know what he had.
If you could post the number on the front passenger side block pad (just in front of the head/block mating point) it could be decoded quickly. While it is possible someone stuck old valve covers, old intake manifold, etc on the truck, it's very unlikely they would have put the cansiter oil filter - so probably is a 283/327, but can't confirm w/o some #'s.
Nice truck by the way, it's certainly no parts truck.
Old 05-06-2012, 08:31 PM   #8
southern parts
southern parts's Avatar
it`s a 307. look at the small balancer.
southern parts is offline   Reply With Quote
Old 05-06-2012, 08:57 PM   #9
PHAT TONY
PHAT TONY's Avatar
Those valve covers have raised letters; sweet!
1972 factory 2 Wheel Drive Blazer-Sold
1972 K10 4X4-Sold
1971 Chevrolet Cheyenne/10-Sold
1970 Chevrolet C/10-Sold
1968 GMC 4X4-Project
1968 Chevrolet C/10 Pro Street
1970 GMC 3/4 Ton-Parts
1997 2WD 2DR Yukon-Sweet
http://67-72chevytrucks.com/vboard/s...d.php?t=335664
PHAT TONY is offline   Reply With Quote
Old 05-06-2012, 09:43 PM   #10
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Get the numbers off of the pad in the front of the passenger side cylinder head and post them here. They are stamped on the pad from the factory. Then we can tell you what engine it is without a doubt.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 05-06-2012, 09:52 PM   #11
mr48chev
mr48chev's Avatar
My guess is that it is a mid 60's 283. That long filter canister was a big truck item in thole years.
Check the block casting number on the block at the back of the engine on the driver side.
The casting number will be in this location
This is a 350 casting number so it won't be the same on yours. The easy way to check it is to hold your digital camera by the firewall pointing down at that area and take a few photos so you can read the number. Then go to one of the sites that lists casting numbers for small blocks. This is one of the lists that most guys use http://www.nastyz28.com/sbchevy/sblock.php
If the engine runs good and is a 283 or better yet 327 all isn't lost as those engines are pretty popular with the traditional hot rod guys who are hunting small journal engines to use.
Old 05-07-2012, 01:56 AM   #12
lil hoodlum
lil hoodlum's Avatar
The truck looks pretty good for just a parts truck.
Judging by the air cleaner I am fairly certain it is a 1967 or 1968 327. Also judging by how the alternator mounts to the exhaust manifold (i.e. no accesory bolts holes in the head.) The canister type of oil filter was also found on the 283 and 327 motors for 1968 and earlier.
You are correct that the distributor is a points type.
If the motor isn't too tired it should be a peppy little motor. I am jealous, I have been wanting to put another 327 back into my truck.
Good luck with the build.
Keith
lil hoodlum is offline   Reply With Quote
Old 05-07-2012, 04:02 AM   #13
sanford66
sanford66's Avatar
I like how the PO used a window crank for the door handle! Other than that you got a nice score! Joseph
1970 Chevelle Nomad station wagon
1966 C-10 lwb,250-six,granny 4speed
1966 C-10 lwb,factory A/C,Custom Cab
1954 Delray 2-door sedan [rat rod project]
sanford66 is offline   Reply With Quote
Old 05-07-2012, 06:47 AM   #14
rsavage
rsavage's Avatar
67 or earlier 283 or 327. 68 no longer had the intake oil fill and I believe that 68 was the first year of spin on filters.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 05-07-2012, 09:19 AM   #15
MARKDTN
68 (at least cars) has a crossover of part styles. It has a spin on oil filter and an intake filler neck. They also got large journal crankshafts. This engine appears to me to be 67 back. Need to get the casting number off the back to get a better idea. All the tin interchanges, but 67 was also the last year for the script valve covers. in 68 they all got PCV valves in the valve covers.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 05-07-2012, 09:22 AM   #16
70cst
70cst's Avatar
No doubt that is a keeper.
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 05-07-2012, 01:46 PM   #17
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I would change the fluids/filters,rebuild the carb and tune it up(maybe an HEI) and see how it runs.You might do a compression check if you don't wanna spend on it before you have an idea of what it is.Looks like a pretty clean truck.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 05-07-2012, 03:13 PM   #18
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
My 69 had the stock motor and a oil canister just like the one in the pics.
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
