Old 05-06-2012, 08:05 PM   #1
Bodi
292 Chevy Langdon headers/Offy Intake woes
I'm putting a set of Langdon's cast headers, and an Offy aluminum 4bbl intake on my 64 Chevrolet C10 with a 292.
The flanges on them interfere with each other when trying to mount them on the head. There is no way to get both the intake, and exhaust in place. They simply get in each others way. It appears that both Langdon's headers, and Offy's intake have flanges a little larger than the stock exhaust, and intake. This may be fine when used with the stock equipment, but, it just isn't jiving when used together. Considering the coin I've got in to all of this, I'm not super impressed.
So, anyone else run in to this problem? I'm really not interested in getting out the die grinder on a bunch of brand new parts. Emails have been sent to both Langdon, and Summit. I wouldn't expect to hear anything on a Sunday, so, that's why I'm here.
Bodi is offline   Reply With Quote
Old 05-06-2012, 08:12 PM   #2
duallyjams
duallyjams's Avatar
Re: 292 Chevy Langdon headers/Offy Intake woes
Are you able to post a pic of your dilemma.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 05-06-2012, 11:08 PM   #3
geezer#99
geezer#99's Avatar
That's normal. Grind them a bit to fit.
The odd shaped washers that go on the studs might need some grinding on them too to make them make flat contact. The thickness of the Offy flange is not the same as the flange on the headers.
Old 05-07-2012, 12:12 AM   #4
Bodi
The Offenhauser intake flange measures the same size as the stock intake. It appears that the oversized flanges on the Langdon headers are what's creating the problem.
Pretty lame that I need to grind on a nearly $300 part to make it fit. Given the size of the flange, I'm not sure they'd even fit with a stock intake.
Old 05-07-2012, 12:51 AM   #5
markeb01
Senior Enthusiast
markeb01's Avatar
Can't help with your problem, but welcome to the forum. Good luck with getting it fixed.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 05-07-2012, 08:35 AM   #6
vin63
It's Better With Nitro
vin63's Avatar
You'll have to machine/grind the flanges so they clear each other when mounted to the head. Here's a photo of the 292 conversion we did in my buddy's Chevy II with the same combination as yours...
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 05-07-2012, 09:50 PM   #7
Bodi
Well, I'll be chopping the ears off my intake tomorrow to make this fit. After measuring carefully, I'm going to put the blame on Langdon's headers. The flanges are just substantially larger than the stock manifold, or than they really need to be. He has yet to return my emails, but, at minimum, he should put this information on his website. It appears as though I am far from the first person to have this problem.
I also ordered some self-equalizing washers from McMaster-Carr to help with the flange thickness differences.... my wallets starting to get pretty thin!
