How to adjust throttle cable?
So I finally realized that my throttle cable is not hooked up right and pedal to the floor does not completely open the carb. How do I adjust the throttle cable? I think it needs to be tightened up a little. Do I do that from the carb end (I have an edelbrock if it matters) or on the pedal itself?
Inside the cab I can see there is about 1 inch of play in the pedal before it starts pulling the cable. Can I just shorten this?
'73 K20 Cheyenne Super Camper Special 350/TH350/NP205 sittin' on 33's. You can set my truck on fire and roll it down a hill, and I still wouldn't trade it for a Coupe de Ville. |
Re: How to adjust throttle cable?
What throttle bracket do you have? Sounds like it might be too close to the carb. As far as I know there isn't any adjustment...
I haven't got a clue. How do I tell? I'll post a pic later.
Is there supposed to be any play in the pedal before it starts pulling the cable? Or should it be tight? I can move the pedal back and fourth about an inch without it moving the throttle.
There shouldn't be that much play. If the throttle bracket were farther from the carb it would take up the play...
Here's a crappy cell phone pic, my other camera wouldn't work. I added a cable clamp to the end of the throttle cable to take out some of the play, and that made a HUGE difference. It's still not the right way to fix it though...I'll try and play with the throttle bracket tomarrow.
To me, that bracket looks to be too close to the carb.
