Old 05-06-2012, 08:57 PM   #1
dukcaln
dukcaln's Avatar
ignition switch sticking in the 72
so, every once i a while the ignition will stick. not as much for me but for the wife and son seems to happen more. I sprayed some lub and worked the key on and off and it seemed to help but even with the lub it would still stick. I have to slide the key back out a tad, wiggle it a tad and then it will work fine for a few days then when you stop thinking about it it will stick again. any suggestions
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP
SOLD 1972 chevy c10
dukcaln is offline   Reply With Quote
Old 05-06-2012, 09:23 PM   #2
The-1ton
The-1ton's Avatar
Re: ignition switch sticking in the 72
try buying a new key cylinder, their 15$ and are easy to replace
The-1ton is offline   Reply With Quote
Old 05-06-2012, 09:35 PM   #3
mr48chev
mr48chev's Avatar
The 1ton is most likely correct if you have to move the key around to get it to turn. The tumbler is most likely pretty well worn out by now and causing that. The other cause may be keys that are worn out. If it just doesn't release and pop back after you hit start the spring in the switch it's self may be bad or weak.
Old 05-07-2012, 12:35 AM   #4
SS Tim
SS Tim's Avatar
When it gets to that point plan on replacing the ignition cylinder and all keys. Keys wear and beat up the cylinder tumblers, especially when a heavy keyring is involved.
SS Tim is offline   Reply With Quote
