05-06-2012, 10:41 PM | #1 |
DND Trucks
69-72 Factory Truck Tilt Auto
This real truck tilt column, (p/n 7810233) was removed from a 72 GMC Sierra Grande. The tilt mechanism is tight and not loose. Shift bowl pin area isn't oval shaped, look at the pics. Wire cover is in place. No surface rust at the base of the column.
This is a good used tilt column that just needs to be cleaned up and installed. I can come up with the correct levers, connector for the gray wire and a hazard knob. And will post pictures of them later. 275.00 shipped CONUS |
05-06-2012, 10:43 PM | #2 |
Just a Member
Re: 69-72 Factory Truck Tilt Auto
can you get this to Indy???
72 C-10 Cheyenne 350/350 ALL ORIGINAL 81,158 miles (1st) 69 7/8 ton(s & l) 66 327 short block rebuild.325 hp(2nd) 70 C-20 88 350 long block rebuild .040 bore. forged crank GM ZZ4 Hot Cam 1.5 roller rockers.375hp Aluminum TH400(3rd) 71 SWB frame off with 68 body. POSI PayPal: remimartin257@aol.com Business Inquires: 812 801 5111 "Help me, help you" that's my motto Members met... BuildinA68, jessewebb, daddymoo2, 70STOVEBOLT, irishfan77, feller, fine69, chevytruckguy70, jamie72, Nohatch, 2112, drtydog |
05-06-2012, 10:43 PM | #3 |
DND Trucks
More pics.
05-06-2012, 10:45 PM | #4 |
Just a Member
I will take it regardless. I will be in Indy Wednesday. Unfortunately pops is back at VA again. I have to get my fenders put via Greayhound too!!! ERRRRGH.
05-06-2012, 10:53 PM | #5 |
DND Trucks
Duane, right now I'm covered up this week. However, I'll pm you payment info and I'll ship it directly to your addy. Sold to HeavyMetalChevy, pending payment.
05-06-2012, 11:00 PM | #6 | |
Just a Member
Duane
05-06-2012, 11:04 PM | #7 |
DND Trucks
05-06-2012, 11:35 PM | #8 |
2nd inline if Duane declines it.
SOLD -77 CHEYENNE SWB, LS SWAPPED -1976 SILVERADO YUBA GOLD/NEUTRAL (2-TONE) |
05-06-2012, 11:41 PM | #9 |
Just a Member
You can have it after I restore it...
05-07-2012, 02:05 AM | #10 |
lol........let me know when its done.
05-16-2012, 05:20 PM | #11 |
Just a Member
Received tilt today... Very nice and solid. Thanks Dave!
05-16-2012, 07:39 PM | #12 |
DND Trucks
You got it. Thanks Duane.
