#1 | |
NP205 side mount question?
What I have is a np205 transfer case on a turbo350. I got the torque bar that runs from the side of the transfer case to the transmision, how good is this bar or should I look for one of the mounts that go from the side of the trasfer case to the side of the frame. Any input on which is the better one to use would be helpful.
76 Chevy Crew Cab Build 6.2 Diesel with a Banks Turbo Turbo350c NP205 Dana 44 Front 14 Bolt Posi Rear Quote:
Re: NP205 side mount question?
Use the bar that runs up to the bellhousing bolt. Do NOT use the brace that bolts to the frame, unless you like to break adapters.
#3 | |
Thanks thats what I wanted to know.
