Hubcap I.D. anyone?
Differences between these caps. One has an outter lip around the tri-design, the other is smooth. I was wondering if anyone has some info?
'66 "Wrong bed" (Long stepper) 350, 4-speed '66 Shortbed Stepside, 350/TH350 www.instagram.com/d_ray_pinstriping |
![]() Join Date: Feb 2010
Re: Hubcap I.D. anyone?
My 66 3/4 ton has the ribbed one. I have seen both in stock form. I think the 64-65 may be the smooth ones and 66 the ribbed ones. Im sure someone else will chime in soon.
1962 C-10
I wonder if it's an OEM/Aftermarket difference? I know some re-pop items aren't exactly like originals...
Joseph Chavez ![]() "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
![]() Join Date: Aug 2010
the smooth ones are early (64-65) and are not reproduced. Those with ridges are from 66 and are being reproduced pretty darn close to original. You can spot subtle differences in the bowtie if you compare an original to a repop. The ridges make them more resistant to damage and are what Chevy would give you for your 64 65 66 if you went to the dealer for a replacement.
Cool, thanks for the info!
'66 "Wrong bed" (Long stepper) 350, 4-speed '66 Shortbed Stepside, 350/TH350 www.instagram.com/d_ray_pinstriping Last edited by DAN66; 05-07-2012 at 12:00 PM. |
Here is a repop
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
They must have rotated the chevy emblem on the re-pop...
1962 C-10
Man... You learn something new everyday. Cool...
Pays to shop around. I have found 2-3 different variation of the repops in the last few minutes alone.
