Old 05-07-2012, 12:56 PM   #1
CdM
CdM's Avatar
donor tbi swap into a 66
Anyone out there swap a tbi ran motor from a gen one or 92 chevy?...
the only thing im caught on is if the computer and harness has to swap or if there is a more (Basic) way of doing things. I have a strong motor in a truck that wont pass smog so i'd like to use and leave the original 327 for a down the road rebuild. Didint see much in the search.. Thanks folks!!
Build Thread 66 custom cab lwb http://67-72chevytrucks.com/vboard/s...d.php?t=465726
66 fleet lwb- In process
64 k10 10inch lift 38.5's- In process
92k1500 400hp on 38.5-parts truck now 8(
CdM is offline   Reply With Quote
Old 05-07-2012, 10:37 PM   #2
scotts62
One day...
scotts62's Avatar
Re: donor tbi swap into a 66
Would not be hard at all to use that style engine verses an LS, yeah you would need the computer and all unless you just wanted to throw and carb on it and go.
Scott
93 crew cab build
Project 62
Old 05-08-2012, 01:20 AM   #3
Captainfab
60-66 Nut
Yes you will need the computer, the wiring harness and all the sensors needed for the engine to run correctly. The TBI swap harnesses are relatively cheap, unless you like to sort thru wiring harnesses.....or have more time than $$.
Old 05-08-2012, 01:49 AM   #4
tincan1966
tincan1966's Avatar
I originally had a 5.7(350) TBI in my suburban, but have since changed to a 427 w/ TBI from a '90 7.4L.
Using a Painless Performanc harness. Very simple hookup.
tincan1966 is offline   Reply With Quote
Old 05-08-2012, 12:24 PM   #5
CdM
CdM's Avatar
Thanks for the info!! I do have more time than money at the moment so I just might be digging around.
