05-07-2012, 12:58 PM | #1 |
71 Center link question.
Guys quick question.
I have a 68 SWB and almost done with the disc conversion. When I put in the caliper and all those parts, I also have to change the inner and outer tie rod, tie rod sleve and center link ? I could find all the parts exept for the center link so wanted to double check. |
05-07-2012, 01:03 PM | #2 |
Re: 71 Center link question.
also is center link and drag link the same thing ?
05-07-2012, 01:17 PM | #3 |
Restoration Virgin!
so did you install a 71 x-member/ parts for your upgrade?
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
05-07-2012, 01:20 PM | #4 |
No just the spindles , rotors, calipers, ball joints tie rods ( inner / outer ) tie rod sleves, master cylinder and all that. i THINK the only thing im missing is the drag link , center link ?
Edit I havent intalled the Inner and outer tie rods yet, still need that drag link?? |
05-07-2012, 01:21 PM | #5 |
This write up is really helpfull. According to this I think all i have to do is the center link?
http://67-72chevytrucks.com/vboard/s...68&postcount=4 |
05-07-2012, 01:37 PM | #6 |
I was thinking, does a company sell a modified Tie rod sleeve ? Which will allow me to use my 68' Drag link and inner tie rod , and use the 71 outer tie rod ? Since the 68/71 tie rods are different size ?
05-07-2012, 01:40 PM | #7 |
Just checked with CPP and they said I can use 73-87 tie rods so I dont have to change my drag link ? Is that even possible ?
05-07-2012, 10:04 PM | #8 |
Restoration Virgin!
I think I would stick with a 71/72 centerlink if I were you...so when you have to replace these in the future you don't have to try and remember what you did....here a quick picture I took of the difference between the 2...
05-08-2012, 09:33 PM | #9 | ||
'69 Chevy SWB
Matt '69 Chevy SWB Fleet, Primer Black; Project No Name '06 Chevy Trailblazer, Blueish Silver?; Wifes DD, Sold '08 Chevy Impala SS, Silver; the new DD, AND IT IS FUN!!! '99 Dodge Dakota R/T, Intense Blue; DD, Sold Quote:
05-09-2012, 02:51 AM | #10 |
67-72 parts collector,…
71-72 centerlinks aren't available new,... So you will have to find a used one.
Just curious,... Did you piece together your disc conversion or buy a kit? The aftermarket now makes bolt-on direct fit spindles so you don't have to change all your steering components. Posted via Mobile Device
