Old 05-07-2012, 01:46 PM   #1
mavdog32
Brake Booster/MC location info....
Ok I have been looking at getting the replacement under cab setup that adds a booster. But lately after looking at a bunch of build threads and stuff I have seen a bunch of people locating them else where, firewalls and under the dash mainly. Is there a good reason for this other than creating space along the frame rail? Does it hang low enough that it could drag on lowered trucks?? Im only going to have one exhaust pipe (turbo) and its probably gonna run down the passenger side so the space is not a concern but the the clearance is. Im not slamming the truck but its gonna be lower than stock by quite a bit.
Just trying to get an idea so that if need be I can take an alternate route. Thanks in advance fellas
C
mavdog32 is offline   Reply With Quote
Old 05-07-2012, 02:28 PM   #2
55Cameo
55Cameo's Avatar
Re: Brake Booster/MC location info....
There is nothing wrong at all with the frame mount set-up. Only thing I remember off hands is you need a special proportioning valve for constant brake pressure and some clearance issues with exhaust and trans crossmember clearance which honestly isn't that bad an issue.
No mine doesn't hang low at all. It's flush with the frame rails and I plan on slamming my truck. I like them better because it hides the whole system for a cleaner look and engine bay.
Build thread:55 Cameo R!! http://67-72chevytrucks.com/vboard/s...d.php?t=519851
55Cameo is offline   Reply With Quote
Old 05-07-2012, 02:36 PM   #3
mavdog32
My thoughts exactly man, I like how clean the firewall looks without all that crap on it. I am trying to figure out where to run all the wiring right now so that you dont see any of it, thinking about bringing it in through the floorboard and mounting the ecm behind the seat.
Old 05-07-2012, 02:38 PM   #4
mavdog32
I am also running the progressive cross member kit that incorporates the booster/MC so Im notworried about clearance with the cross member.
Old 05-07-2012, 03:49 PM   #5
55Cameo
55Cameo's Avatar
I'm the kinda guy that loves little detail stuff. It all adds up in the end. I'm also gong for a simple clean install. I ran all my wiring for the front under the fender well and under the hood latch support panel. I drilled a hole in the lower corner near the driver vent to send the harness up front. Worked ok but to big a bulge to cover up. I'm thinking of going higher on the the side level with the dash for next time.
For the engine I plan on mounting the ecm inside just like you and drilling a hole low on the firewall near the trans tunnel hidden behind the motor.
Good deal on the crossmember.
Old 05-07-2012, 09:26 PM   #6
OrrieG
OrrieG's Avatar
Mine is even with the bottom of the frame rail too. I made my brackets.
OrrieG is offline   Reply With Quote
Old 05-07-2012, 10:57 PM   #7
55Cameo
55Cameo's Avatar
Here's a pic of mine for reference. I know it needs some cleaning LOL!!
Old 05-08-2012, 01:14 AM   #8
parkwood
parkwood's Avatar
One is the bolt in M/C and booster from TCI in a '52 sub and the other one in in a '57 truck also from TCI
parkwood is offline   Reply With Quote
Old 05-08-2012, 01:18 AM   #9
mavdog32
Nice, lookin good fellas. Thanks for the info, I think I will be sticking it under there. Like i said I would like that clean firewall appearance especially since the rest of the engine bay is going to be pretty busy.
Old 05-08-2012, 08:52 PM   #10
_Ogre
_Ogre's Avatar
i run an 03 mustang hydroboost under the floor on my 58
home made everything, $100 junkyard hydroboost
after some problem with a leaky caliper, i found a remote reservoir to add to the system
and yes, i like a clean firewall
shop air compressor timer
Old 05-09-2012, 02:00 AM   #11
mavdog32
You know I thought about Hydroboost, especially running a turbo motor. I was under the impression that the pump for a rack and pinion steering wouldnt put out enough pressure to run a hydroboost.
FWIW I Run a ported hydroboost in my rock crawler and it will lock all four up QUICK!
Old 05-09-2012, 11:26 AM   #12
_Ogre
_Ogre's Avatar
If your experienced with hydroboost, I'd use it.
I run a ford rack and ford hydro with a gm pump
Just ordered a flow reducer to tone down the steering
Old 05-09-2012, 12:18 PM   #13
mr48chev
mr48chev's Avatar
I am a hard core proponent of keeping the master cylinder under the floor even if you have to work around it a bit on some applications. The main reason is not having the clutter on the firewall.
I had a hydroboost on the 77 Chev 1 ton 4x4 that I had for a few years and that truck had the best feel to the brakes of any truck I have ever owned. I'm seriously thinking about putting that setup on the 48.
Old 05-09-2012, 12:35 PM   #14
oldcouple
oldcouple's Avatar
I have the TCI Bracket in my 56, only problem I have is the mc leaks all the time. It called for a mustang unit, I have swapped it out twice, same problem. Any clues on what is going on?
Retired and too busy to work.
oldcouple is offline   Reply With Quote
Old 05-09-2012, 03:16 PM   #15
_Ogre
_Ogre's Avatar
cheap rebuild units. after the caliper leak i ran the rear dry and it caused the mc to go bad. took 3 rebuilt units to get one that would bleed and wouldn't leak. if it a newer mustang mc, look at my built for how i put the remote fill on my 03 mc. same mc 01 to current i believe.
Old 05-09-2012, 10:50 PM   #16
oldcouple
oldcouple's Avatar
Thanks Ogre, sorry for the thread Hijack..
Old 05-09-2012, 11:10 PM   #17
mavdog32
Hey it produced info that someone can use so I don't mind at all
Old 05-11-2012, 08:03 AM   #18
lonelywanderer
i got the cpp frame mount set up on my 59, its super crowded next to my trans crossmember. gonna order a remote reservoir kit cause i dont want to hack my floor up and dont want to always go under the truck to check the fluid level
lonelywanderer is offline   Reply With Quote
Old 05-11-2012, 09:54 AM   #19
Dan in Pasadena
Dan in Pasadena's Avatar
Ogre, Didnt you post somewhere else that the remote reservoir is off a Nissan Quest or some such minivan? I'd love to hear more about WHICH '03 Mustang that hydro boost came out of - GT? Cobra? Other? And see how you mounted it?
Dan in Pasadena is offline   Reply With Quote
Old 05-11-2012, 07:22 PM   #20
_Ogre
_Ogre's Avatar
yes, the remote reservoir came from a nissan quest. same as the mercury villager i believe.
the hydroboost was in the cobra, the had a bigger motor and the gt vac booster wouldn't clear it.
i found the remote fill option on a factory five site, they use the same mc stuck way under the fender
the f5 guys couldn't figure out how to use a fill bottle
as for the mount, all custom (home made). i just start cutting and welding.
i made a 3/8'' mounting plate that blends with the frame boxing, so the whole thing unbolts
