05-07-2012, 03:33 PM | #1 |
Seats out of 06 Silverado fit?
Found some 40/20/40 seats out of a 2006 Chevy.
Will they fit in my 86? I know I'll need custom brackets, but worried about width and general fitment. These are out of 88-98. Would they fit better in the old chevy?
Robert Current: 1986 SWB Silverado 4.3 / TH400 Past: 1985 SWB Silverado 305 / TH350 - sold 1995 1987 1/2 ton Silverado - FI 350 / 700R4 sold 2007 |
05-07-2012, 03:42 PM | #2 |
Ephesians 2:8
Re: Seats out of 06 Silverado fit?
You can run either seats, its just at what level of simplicity do you want.
I'm running a 60/40 from a 95 C1500 in my 79 C10. My nephew is running 04 40/20/40 seats in his 81 K20. I was able to make the 95 seat to sit on the factory slides from my bench seat. He took a different approach and flattened the floors on his cab to allow the newer seats to fit. You have to modify the brackets of the 99-07 seats, since they are an integrated frame/bracket set up, if you don't want to modify your floors. 88-98 Seats can be separated, frame and brackets are separate. I'd put my money on the 88-98 seats, however, it is nice to have the seat belts built into the seats. I'm not sure I really even helped you here
72 Suburban making it mine My 79 C10 story 79 C10 LS swap 94 LS swapped Daily Driver Tahoe Limited Instagram - @piersonclassics 83 K20 Farm Truck Build |
05-07-2012, 03:43 PM | #3 |
Im putting 04 in now I'm 6'1" my head hit the roof. To get them even with back glass u will have too remove tanks and put a c channel in and lower it about 2-2 1/2 inches that puts them at factory seat height. But u will have to put diff fuel tank in
Posted via Mobile Device |
05-07-2012, 04:37 PM | #4 |
Sounds like the 06 seats need more fab work to get them to fit right. The built-in seat belts don't really affect my decision. I'd actually prefer the stock seat belts.
The only drawback to the 88-98 buckets is no middle fold down seat, which I need with 2 kids of my own.. Did they make a 40/20/40 seat for 88-98 ?
05-07-2012, 04:47 PM | #5 |
Ephesians 2:8
They did a 60/40 with a fold down arm rest from 95-98. That is what I have in my 79. Since mine is a 95 seat, I dont get the flip down arm rest/console with storage, just a large arm rest.
You can also use Dodge Ram seats from like 94-2000 ish, when ever the body changes, could use newer ones, but I'm not sure on compatability. I've done that in the past, that dodge ram arm rest/storage is HUGE! To adapt these to my factory slides, I used 1.5" cube steele to make a frame, bolted frame to the seats, welded frame to slides. You end up with a 60/40 bench seat :-) I looked for a pic of my seats, but didn't come up with anything, I'll try and snap one tonight for you.
05-07-2012, 05:43 PM | #6 | |
05-07-2012, 06:05 PM | #7 |
I would also check out Chrysler Sebring convertible seats with integrated belts. I don't know how they would work but I think they are lower overall, and a bit narrower.
Example: http://www.ebay.com/itm/CHRYSLER-SEB...e71c5e&vxp=mtr Last edited by tucsonjwt; 05-07-2012 at 06:33 PM. |
05-09-2012, 11:01 PM | #8 |
Ephesians 2:8
As promised :
Posted via Mobile Device Sorry my truck is so dirty..... its been neglected this spring
