docs blocks
docs blocks no longer carries these ac lines commonly used in LS swaps anyone know any other sources?
Product ID: AA2210 Product ID: AA2209 We are out of stock on both of these parts and will not be restocking them. Sorry for any inconvenience this may cause. Michele Dean Customer Service Rep. Stark Manufacturing, LLC Phone: 479-968-8840 ext 1330 Fax: 479-968-8009 email: mdean@starkmfg.com
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
Re: docs blocks
I have been down that road also. No one is selling anything that i can find that will work. I even talked to a buddy at vintage air about it with no luck.
___________________ 78 ccsb dually 5.3 4l60e http://67-72chevytrucks.com/vboard/s...d.php?t=491551 |
Still Just Havin Some Fun!
![]() Join Date: Jun 2007
Re: docs blocks
I purchased the factory LS lines from a parts store and had a shop swap the other end to fit my setup.
a green one with some stuff done to it.... |
#4 | |
![]() Join Date: Dec 2007
Re: docs blocks
1950 Chevy 3100 Ramp Bed 1-ton http://67-72chevytrucks.com/vboard/s...d.php?t=749386 1965 Chevy Step Side 1971 Chevy Short Wide Bed http://67-72chevytrucks.com/vboard/s...d.php?t=277191 1971 Chevy Chevelle 1972 Chevrolet C-30 1 ton 2002 Winnebego Class A MH Ford E-550 Chassis V-10 2005 Dodge Ram 2500 5.9 Cummins 2008 GMC Denali 2020 Jeep Wrangler Unlimited Rubicon |
Re: docs blocks
I'll take it PM me for payment info
Re: docs blocks
PM sent
Re: docs blocks
I plan to do something similar to this. I will probably use the LS hoses, cut off the end and weld an appropriately sized -AN o-ring male fitting to the end of it. My goal is to make something that looks similar to the Doc's Blocks fittings.
1972 C10 "Shop Truck" Build - EFI, 5-speed, Posi, and Patina http://67-72chevytrucks.com/vboard/s...d.php?t=834292 1957 Chevy pickup - Twin Turbo 5.3/NV3500, Jag IFS & IRS, AirRide http://67-72chevytrucks.com/vboard/s...d.php?t=606987 Check me out on YouTube - "Tiny Garage Fabrication" http://www.youtube.com/oneoffstroker |
![]() Join Date: Dec 2006
Re: docs blocks
any updates on this topic?
Re: docs blocks
Try! http://www.nostalgicairparts.com/ac/...dapters-79.php
Posted via Mobile Device Posted via Mobile Device |
Re: docs blocks
A company cslled Trans air now carries them. Thry buy tgrmnin bulk from docks i just got some. When
I get down to my shop later ill get some part #'s. |
Re: docs blocks
Trans air pt#s 313558 , 313556
Re: docs blocks
Phone # 800-673-2446
#13 |
Re: docs blocks
Trying to understand post10 I think your trying to say you have to buy in bulk if so then how many in bulk and how much are they if you don't mind me asking? I'm going to need some
#14 |
Re: docs blocks
Trans air buys them in bulk from docks. You can purchase them from trans air.
#15 |
Re: docs blocks
Thanks do they have a web site
#16 |
I'm just glad to be here!
Re: docs blocks
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
#17 |
Still Learning
Re: docs blocks
Anyone know if these are still good part numbers? Will they work with Vintage -Air stock hoses? thanks
#18 |
![]() Join Date: Apr 2005
Re: docs blocks
Mike those look like standard #8 and #10 fittings. You should have no problem with them working with the Vintage Air hose setup.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#19 | |
Still Learning
Re: docs blocks
When I look these part numbers up at the transair site I can't find the 313558 fitting and the 313556 looks like a straight fitting. Don't we want a 90 degree fitting? |
#20 | |
Re: docs blocks
http://www.vintageair.com/catalog.asp If you still have the original block, I would just take it to a high pressure hose shop and have them build you what you need.
#21 |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
Re: docs blocks
I have the docs blocks on my LS swap with stock truck compressor and ECE mounts, I chose the earlier model compressor because I was told it would work better with the Old Air products AC system I have.
I was told the newer compressors have variable valving ( I think that is what they said) and it will cycle way too much for these aftermarket systems. Remember I am not an ac guy, I am only regurgitating what I have been told and it may or may not be accurate. would this work? http://www.acsource.com/hoseblockhor...oringtype.aspx
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
#22 | |
Still Learning
Re: docs blocks
#23 | |
Re: docs blocks
#24 |
Re: docs blocks
Has anyone have any left?
Or has anyone found a replacement? This is going to be my only solution for the way my motor sits.. Help!? Roadflareguy@hotmail.com Rob |
#25 | ||
Re: docs blocks
I would try the info in the quotes below. Let us know how it works out.
