Old 05-07-2012, 10:39 PM   #1
Tim Christian
Tim Christian's Avatar
Rearend ???????
I figured one of you 73-up guys can answer this Will a 1972 2 wheel drive leaf spring rearend fit a 73- up 2 wheel drive truck???? Thanks
Tim Christian is offline   Reply With Quote
Old 05-08-2012, 10:17 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Rearend ???????
Anyone?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 05-10-2012, 08:32 PM   #3
Tim Christian
Re: Rearend ???????
I would of thought one of you guys would have tried this at sometime or another?????
Old 05-10-2012, 08:52 PM   #4
'82 steppin
'82 steppin's Avatar
Re: Rearend ???????
I dont know about that but you can make it fit I put a rear end from '95 Impala SS to my '82 I had to do little work for leafspring mounts and brake lines and found it the rear end is little shorter no big deal made 1/4 spacers and put Moser long studs
'82 steppin is offline   Reply With Quote
Old 05-10-2012, 10:13 PM   #5
ghettoluxury
ghettoluxury's Avatar
Re: Rearend ???????
Your problem is going to be spring pad width. The 67-72 trucks have a narrower pad width. You can always grind them off and re-weld them, like I had to do when installing the '04 14 bolt in my crew cab.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
