Trac-Bar / Panhard bar Torque Specs
I'm torquing my rear suspension to spec and I have an adjustable rear trac-bar like seen from Porterbuilt or No Limit
Does anyone know the correct torque specs for the bolts/studs that go thru the trac bar ends (heim joints) ?? I'm a notorious over tightener and the assembly manual seems high at 135 ft/lbs if I am reading it right. Don't want to bind anything or limit travel |
Re: Trac-Bar / Panhard bar Torque Specs
Typically the torque spec will be directly related to the bolt size and grade. Do you know what size the bolt is, and what grade it is?
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
Nate - I'm going off memory from last night but I believe this is correct
Upper Bolt: Grade 5 - 1 1/8" Lower Bolt: Grade 8 - 15/16" |
#4 | |
![]() Nate
Something like this?
http://www.cncexpo.com/InchBoltTorque.aspx Thanks Nate - Always learning Looks like 100+ft/lbs might not be that far out of line |
Nate - just out of curiosity and completely understanding your information will not apply to my specific application
![]() What would you recommend to someone torquing the bolts holding the trac-bar in your kit to? Just want to see if I am in the ball-park and not way out of line when i cross-reference my diameter later |
