05-07-2012, 11:27 PM | #1 |
Marine/boat 6 cyl questions
I guy brought this 6 cyl boat engine in the scrap, he said it is a good engine he had saved for years for a boat project but never used.
I asked a mechanic who's brother is a boat mechanic and he said the engine will work fine in a truck. It has looser clearances and a mild cam for boat applications, but will haul @$$ in a truck. I pulled the oil cap and it is as clean as new in the valve area, so I am thinking it may be a good runner. Anyone know if this is correct info on it being able to be run on the street ?
1965 long bed ( grandpas old truck ) 1964 long bed BBW Custom Cab 1966 Short stepside 1964 long bed 1965 long bed Custom Cab, factory air, V-8, powerglide |
05-08-2012, 01:32 AM | #2 |
60-66 Nut
Re: Marine/boat 6 cyl questions
Yes you can run a marine engine on the street. It will run just fine, in fact some guys will put a marine spec cam in their regular automotive engines because they like how they run. Of course you will have to change the intake/exhaust and the thermostat housing.
05-08-2012, 06:17 AM | #3 |
Check The Champ, Demonstrator
Make sure this is rotating in the right direction and was not the opposing twin from a dual inboard.
05-08-2012, 06:15 PM | #4 |
Also, most boats don't have the vacuum advance distributor you find on cars. Boats don't get bogged down on acceleration like cars do because the propeller slips in the water. A marine engine on the street might experience hesitation because of this.
Posted via Mobile Device |
05-08-2012, 06:53 PM | #5 |
also that is an aluminum valve cover that guy's will polish up and run. it's a chevy 250
05-08-2012, 07:44 PM | #6 | |
