Old 05-08-2012, 12:00 PM   #1
BAMO
8 Lug Disc Brake Conversion Kit
Does anyone know if this exists for an 8 lug (c20) - http://www.performanceonline.com/196...ION-KIT-5-LUG/
It looks like it's just a bracket that mounts to the existing knuckle/spindle. I found some place that can make them - http://www.blackbirdscustomtrucks.com/- but I would need to send my knuckle and such to them for them work off of (and then the cost is likely higher and I'd might as well just get donor parts from the junkyard (spindle, tie rods ball joints...etc form a 73-87) and do the swap that way).
Thoughts or ideas (I've checked threads here and of course been googling away, so figured someone must have come across this if it exists).
Frank
http://backyardbuilt.tumblr.com
BAMO is offline   Reply With Quote
Old 05-08-2012, 12:38 PM   #2
1963c-10
1963c-10's Avatar
Re: 8 Lug Disc Brake Conversion Kit
Theres one for sale on ebay right now. Selling as 3/4 -1 ton 8 lug disc kit for 63-72 c-20/c-30 truck. Currently at $100
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 05-08-2012, 01:16 PM   #3
BAMO
That would do the trick as well...too bad he is way to far north of me to make life easy.
Frank
Old 05-08-2012, 01:52 PM   #4
1963c-10
1963c-10's Avatar
These dont pop up very often, I would keep my eyes on it.
Old 05-08-2012, 02:04 PM   #5
billd5string
billd5string's Avatar
I'm about to do the exact same thing to my 65 C20 this weekend.... assuming I can get the parts locally anyway.
In regards to the setup on ebay - will that work okay with the stock pitman arm and idler arm? I thought they needed to be changed over to the later model truck as well.
65 C20 Fleetside longbed, 350, turbo 400, 8-lug disc brakes, power steering, air conditioning - Totaled by a guy running a red light. Pulling parts off the carcass for my next truck
billd5string is offline   Reply With Quote
Old 05-08-2012, 02:07 PM   #6
1963c-10
1963c-10's Avatar
Hmmmm.... sounds like a question for CaptainFab. He seems to be the resident expert on these mods.
Old 05-08-2012, 02:54 PM   #7
Budman56
Budman56's Avatar
Better jump on that deal i paid well over $900.00 for my kit from cpp!! But seeing that is on ebay i bet it will go for about 400 to 500 before the auction is over.
MY 65 C20 BUILD
http://67-72chevytrucks.com/vboard/s...d.php?t=483346
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
Budman56 is offline   Reply With Quote
Old 05-08-2012, 03:25 PM   #8
BAMO
Well not sure he wants to ship, but even if he does, it won't be cheap.
What I was looking for was basically something that "mounts to your original spindle" which is what the POL kit does. I know the other 87 lug kits are there and I know I can get a donor 73-87 and pull things off. Just wondering anyone came across bolt on brackets.
Frank
Old 05-08-2012, 04:36 PM   #9
1963c-10
1963c-10's Avatar
400-500 is still better than 900-1100
Old 05-08-2012, 11:38 PM   #10
Budman56
Budman56's Avatar
If I had to do it all over again, I would go get a 71 3/4 ton complete front cross member spindle top spindle with disk brakes and redo it and bolt it in, you only have to re drill two holes, you can find them on craigs list every once in a while.
MY 65 C20 BUILD
Old 05-09-2012, 01:07 AM   #11
Captainfab
60-66 Nut
I wouldn't even bother messing around trying to put discs on drum spindles. I see absolutely nothing to gain when it is so easy to just switch to the '71-'87 C20 spindles, rotors, calipers, etc. The only thing I have not confirmed yet, is whether or not the '63-'66 C20 lower control arms will accept the '71-'87 C20 lower ball joints. I am pretty sure they will fit, but I just have not confirmed it.
Old 05-09-2012, 01:09 AM   #12
mMad Dawg
I have been thinking about doing this on a 69 3/4 ton Chev. If you change to the 71 to87 3/4 ton balljoints then you ca use the spindle from 71 to 87. You will have to do somthing about the tierods,but if you use the relayrod and tierods from the donor vehicle all you need then is master cylinder and brake hoses. You can either reroute your front brake lines or leave them and get longer hoses. hope this helps.
mMad Dawg is offline   Reply With Quote
Old 05-09-2012, 01:38 PM   #13
BAMO
Ok, that's kind of where I figured this was heading. I can bolt the whole upper and lower control arms from the 71-87 right on as well, right? Also, is there any way to identify the parts on the 71-87's as opposed to 88 and up? Just want to make sure when I go on the hunt (if the rest of the vehicle isn't there).
Frank
Old 05-09-2012, 05:26 PM   #14
BAMO
And to that end...picked up spindles, rotors, upper/lower control arms for $120 off a 73-87, so guess no need to worry about a bracket anymore.
Frank
Old 05-10-2012, 12:49 AM   #15
munchieu
I just used a donor and unbolted my 66 8 lug complete front suspension crossmember and all and rolled in one from an 82. Easy and cheap! all one shot. drill two extra holes and if i remeber right, elongate two holes.
munchieu is offline   Reply With Quote
Old 05-10-2012, 01:07 AM   #16
Captainfab
60-66 Nut
The '71-'87 lower control arms will not bolt up to the '63-'66 C20 suspension crossmember. On the '63-'66 C20's the lower control arm shafts are flat, so there is no sadddle on the crossmember as there is on the '67 and up C20's. The '71-'87 lower control arm shafts are round and require the saddle on the crossmember. Before you get too carried away, check to see if the '71-'87 lower balljoints will fit the '63-'66 lower control arms. If not, you can either switch the control arm shafts, or the entire crossmember.
Old 10-31-2012, 02:57 PM   #17
1955 mancave
1955 mancave's Avatar
would that also be the case on a 64 C30, would i be able use a entire crossmember from a donor truck that has disk brakes.
1964 1 Ton flatbed service truck (sold)
1964 C-10 panel (project complete frame up build)
1957 210 post pearl orange
1955 mancave is offline   Reply With Quote
Old 10-31-2012, 11:17 PM   #18
Captainfab
60-66 Nut
Yes. But you will want to look for a '73-'86 C30 or '87-'91 R30 (R3500) with dual wheels, since your '64 is a dually. The front hubs, rotors and spindles are different than for a single wheel C30 or a C20.
Old 11-01-2012, 06:16 AM   #19
tincan1966
tincan1966's Avatar
I have a complete change-over crossmember to covert that C-30 to discs and its all new. I bought brand new control arm from dorman-come with balljoints and shaft kits installed-about $125 each. Also has new hubs/rotors, calipers, pads, bearings, seals, tie rods, hoses,Monroe Magnum shocks. Only about 2000 miles on it all.
it's the 1976 chevy dually discs, with the JB 8 brake setup(largest GM made then)
I am selling as a unit, ready to bolt it w/sway bar, the frame stiffener plates that are OEM, bolts, etc.
PM me if anyone needs it- can be shipped truck freight.
tincan1966 is offline   Reply With Quote
Old 11-03-2012, 10:09 PM   #20
1955 mancave
thanks, for the info, so then i was off to Craigslist land and found one as you stated, i will pull it next week, i got it for $100.00 for everything, so i'm feeling pretty good so for around what i have in parts and the brackets i bought from you,i should have have P/S P/B with disks and be in at around $300.00 it pays to do research.
Old 11-04-2012, 12:44 PM   #21
HEI451
Captianfab, is there any way to tell just which setup it is for the single wheel vs the dually for the later C30's? I have a full cross member off a later C30 for my 1964 C30 dually, how can I tell which later front I have? I'd just change the entire cross member, but the person that gave me the thing cut it off literally around the rear bolts to the A arms, and it ain't pretty, and isn't going to be workable to fit up.
HEI451 is offline   Reply With Quote
Old 11-05-2012, 12:11 AM   #22
Captainfab
60-66 Nut
Do you have just the spindle and no hub and rotor?
Old 11-05-2012, 12:24 PM   #23
1955 mancave
nope it will be complete with A arms , all the center link, etc. i'm getting the whole thing with steering box,
opps never mind you were not asking me ! my bad lol
