Old 05-08-2012, 04:47 PM   #1
1stchevy
1stchevy's Avatar
Help identifying brake booster
PO installed the booster on my truck and I'm pretty sure it isn't working. I have a new master cylinder and prop valve and the pedal is hard as heck to push down. I checked vacuum from the engine and it's pulling pretty good. Any help is greatly appreciated.
Chris
1stchevy is offline   Reply With Quote
Old 05-08-2012, 06:26 PM   #2
425HP409
425hp409
425HP409's Avatar
Re: Help identifying brake booster
To test a vacuum booster,
First: with the engine off, depress the pedal three or four times to remove any residual vacuum in the booster.
Second: hold pressure on the brake pedal and while holding it down, start the engine
Third: If the booster is operating correctly, the pedal will go down when the engine started while you are still holding pressure on the brake pedal.
Charles
68 SWB, Dad bought new, now 396 & factory ac
64 Impala SS, 409 425HP, 4 speed AC
64 Bel Air Wagon, 400 Small Block
57 Bel Air all original 283 w/Factory Air
77 GMC Sprint, 454/425HP
67 Olds 442, all original
90 ZR1 Corvette
425HP409 is offline   Reply With Quote
Old 05-08-2012, 08:03 PM   #3
1stchevy
1stchevy's Avatar
I've tried that also, the pedal drops very slow and I feel like I have to stand on the brakes to get them to stop.
Old 05-08-2012, 08:03 PM   #4
68gmsee
Active Member
68gmsee's Avatar
I have one similar to yours that I used on my 69 Chevy. It's been many years ago but I recall taking it the booster off a 77 Chevy Impala.
Has the truck always had this problem?
It does sound like the booster is bad. After you check as mentioned above and before you condemn it to the scrap pile, check the linkages real careful. Make sure the problem is not the adjustment on the pushrod link between the booster and master cylinder. It has to be correct and they do make two styles of master cylinders. One with the recessed piston area being shallow and another that's deeper. The pushrod has to match.
Also, there's a possibility the proportioning valve is malfuntioning and/or the brakes/pads have become glazed over.
68gmsee is offline   Reply With Quote
Old 05-08-2012, 08:37 PM   #5
1stchevy
1stchevy's Avatar
Yes the truck was like that when I bought it. I purchased the truck about a year ago and installed front disc and 5 lug swap and 4/6 ECE drop and I've only driven the truck around the block a few times because the brakes are so hard to get to stop.
Old 05-08-2012, 09:18 PM   #6
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
This is probably a good question to ask here as it could be your problem.
I was told that if your running a cam, it may not have enough vacuum to properly run the booster.
Thats what I was told by a local custom shop here in Albuquerque when I inquired about a brake booster.
Can anyone confirm this?
Chirs, have you measured your vacuum or just used your thumb to feel it?
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 05-08-2012, 09:34 PM   #7
1stchevy
1stchevy's Avatar
It has got a bit of a lope to it and I've only checked vacuum by feel.
Old 05-08-2012, 09:56 PM   #8
68gmsee
Active Member
68gmsee's Avatar
I would just go get a vacuum gauge at local auto parts and check the engine vacuum at idle. These gauges are fairly cheap and a good tool to have to adjust idle/air and carb settings.
Old 05-08-2012, 10:01 PM   #9
1stchevy
1stchevy's Avatar
Thanks 68gmsee I'll pick one up and check the vacuum on it. If it is a bad booster would I be able to just get either the Delco or Bendix booster and bolt it on.
Old 05-08-2012, 10:06 PM   #10
68gmsee
Active Member
68gmsee's Avatar
Yes. The better ones will cost you some dollars. I prefer buying local myself since I can always return them if it's not what I want or if defective but be aware that they're usually a cheap rebuild.
Old 05-08-2012, 10:07 PM   #11
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Also check the check valve.It should have a directional arrow on it.The arrow should point away from the booster.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 05-08-2012, 10:11 PM   #12
1stchevy
1stchevy's Avatar
I'll check it also thanks Panel!
Old 05-08-2012, 10:24 PM   #13
1stchevy
1stchevy's Avatar
When you say better ones I guess your referring to a brand new booster not a remanufactured one.
Old 05-09-2012, 08:37 AM   #14
1stchevy
1stchevy's Avatar
So does anyone have any clue as to what kind of booster I currently have installed on my truck? And do any supporting vendors have new boosters for sale?
Old 05-09-2012, 01:16 PM   #15
1stchevy
1stchevy's Avatar
ttt
Old 05-09-2012, 02:19 PM   #16
red69ss
Burnouts are therapeutic
red69ss's Avatar
it looks similar to the one on my truck, which I was told came off an 84 c10.
If it were me I would go to a stock booster for one of these trucks, thats what I plan to do if something happens to mine. The reman. ones are less than $100, you may have to use a stock bracket and rod if you went that route.
Here's a pic of the one on my truck, I got this booster with the truck and I pulled the master cylinder off the firewall and installed it . it works great.
1969 CHEVELLE SS
1972 C10 ALMOST DAILY DRIVER
1968 C10 RUSTBUCKET (MISSION IMPOSSIBLE)
1972 PONTIAC LEMANS CONVERTIBLE (WIFE'S CAR)
"My wife and I were happy for twenty years. Then we met." - Rodney Dangerfield
"The difference between genius and stupidity is that genius has its limits." - Einstein
red69ss is offline   Reply With Quote
Old 05-09-2012, 02:21 PM   #17
1stchevy
1stchevy's Avatar
Thanks for the info red69ss!
Old 05-09-2012, 02:37 PM   #18
red69ss
red69ss's Avatar
no problem , after going back and reading your post I think 68gmsee is pointing you in the right direction. I would check the vaccum with a gauge ,if you have a lot of cam you may need a vaccum canister. I've never dealt with this but the guys here can help you through it.
The last truck I had the brakes were not great on , I always blamed it on the fact it had a small seven inch aftermarket booster on it . The truck had a pretty big cam in it and it could have been the vaccum instead. good luck
1969 CHEVELLE SS
Old 05-10-2012, 08:57 AM   #19
1stchevy
1stchevy's Avatar
Checked vacuum from the engine it's good and when I pull the check valve out of the booster I also get the burst of air. I'm thinking the booster on my truck might be a 3/4 ton booster and the master cylinder is for a 1/2 ton. Can anybody tell by looking at my pics?
Old 05-10-2012, 10:18 AM   #20
68gmsee
Active Member
68gmsee's Avatar
Possibly, yes. It should work though. I have the same booster I used on my 69 1/2 ton. Can't tell from the pic what m.c. you have. Maybe if you post a pic of the master cylinder itself.
Also, give us a little more info on your truck. Year, 1/2 ton or 3/4 ton? I'm assuming disc/drum but additional conversion to all disk?
One other thing to be aware of is that in some instances the rear and the front lines were reversed and on disc/drum it does make a difference.
Old 05-10-2012, 06:04 PM   #21
1stchevy
1stchevy's Avatar
The truck is 69 1/2 ton with a front disc conversion, 1/2 ton master cylinder and prop valve rear is drum. I know that a 3/4 ton booster and a 1/2 ton master cylinder will not work together. All of the 1/2 ton boosters I've seen have a recessed area that the master cylinder bolts to and the booster on my truck is flat.
Old 05-10-2012, 07:06 PM   #22
68gmsee
Active Member
68gmsee's Avatar
Booster face is flat? I don't think I've ever seen one. All I've ever seen also have a recessed center.
Any chance you can get a number of it?
Old 05-10-2012, 07:11 PM   #23
68gmsee
Active Member
68gmsee's Avatar
Here's a site to do a comparison.
http://www.getdiscbrakes.com/disc-br...-brackets.aspx
Old 05-10-2012, 07:51 PM   #24
1stchevy
1stchevy's Avatar
Yes booster face is flat. I'll try to get a number later.
