Old 05-08-2012, 04:57 PM   #1
shuvl
shuvl's Avatar
200-4r installation questions
Gonna be putting one in my truck. Few questions I have. Lock up converter, where is the best place to get one? Do the splines on my stock drive shafts match up to the tranny? Will the drive shaft need to be shortened? Which fly wheel will I need? In short, I pretty much don't know much. Can ya help steer me in the right direction? I have a lift, tranny jack and a few gear head friends at my disposal but want to do this over a weekend so I'm trying to get all my stuff together so it'll run on Monday, being it's my daily driver. Thanks in advance.
shuvl is offline   Reply With Quote
Old 05-08-2012, 05:02 PM   #2
hopped up
hopped up's Avatar
Re: 200-4r installation questions
id like info on this too. been thinking this or 700r4
hopped up is offline   Reply With Quote
Old 05-08-2012, 05:45 PM   #3
jchav62
1962 C-10
jchav62's Avatar
What transmission are you currently running?
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 05-08-2012, 05:51 PM   #4
shuvl
shuvl's Avatar
Stock 3speed with an I6 250
Old 05-08-2012, 06:03 PM   #5
jchav62
1962 C-10
jchav62's Avatar
The driveshaft will need to be shortened. As far as the flywheel (flexplate), I'm not too sure about the sixes. You have two options, the 153 tooth or 168 tooth. Usually the way the starter mounts to the engine block determines which flexplate you need... bolts straight across, 153, bolts staggered, 168.
Another thing you need to pay close attention to is the TV cable. You'll need to fab a bracket to the intake manifold to install that. It may be tricky (but not impossible) to get the correct geometry on a six...
You'll need a crossmember, trans cooler/lines... if you don't already have that.
Oh yeah, you'll need another starter too. Your's is mounted to the bellhousing with the standard trans. You'll need an engine block mounted starter.
Joseph Chavez
Old 05-08-2012, 07:00 PM   #6
gimmy 64
the 2004r is close to the length of the 350 i don't know about 3 spd. 168 tooth fly wheel. starter for an automatic. splines on output shaft the same.as far as the lock up for tork conveter i bought my trans from gearstar. the lock up was a small switch that has electric from key start and full vacume off carb and thats it.
gimmy 64 is offline   Reply With Quote
Old 05-08-2012, 07:04 PM   #7
TopFuel1966
TopFuel1966's Avatar
Try these guys..........
http://bowtieoverdrives.com/index.shtml
TopFuel1966 is offline   Reply With Quote
Old 05-10-2012, 01:40 AM   #8
shuvl
shuvl's Avatar
Thanks for everyone's advice, appreciate it.
Old 05-10-2012, 05:30 AM   #9
jj1965
jj1965's Avatar
I agree with the Bowtie Overdrives post. I was able to get everything I needed to do my swap and build my transmission. They have lockup converters and all the wiring to complete the swap. Make sure your TV valve is right or you will destroy your transmision, A pressure gauge is critical to check its adjustment. You will probably need a different yoke on your driveshaft if it is original the slpines on early transmissions are larger.
jj1965 is offline   Reply With Quote
Old 05-10-2012, 12:21 PM   #10
61K10
61K10's Avatar
had one in a 65 elco and used a tci non lock up conv.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 05-10-2012, 02:46 PM   #11
DLOE65
DLOE65's Avatar
I have a 200r4 on a 292. Check my build for pics, I used lokar throttle and kickdown cables
DLOE65 is offline   Reply With Quote
