Old 05-08-2012, 05:54 PM   #1
perro13
perro13's Avatar
292-250 swap HELP
I never have swaped out a 292 t0 a 250. what has to be down motor mount wise.I know pass side are different (location). What i need to do. thanks
perro13 is offline   Reply With Quote
Old 05-08-2012, 06:07 PM   #2
jchav62
1962 C-10
jchav62's Avatar
Re: 292-250 swap HELP
I think the pass. side engine tower needs to be moved back. The holes are already on the frame and the crossmember. If I remember right, the same tower can be used..
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 05-08-2012, 06:15 PM   #3
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
the passenger side on a 292 is different than the SB or the 230-250 6 cylinder mounts. you need to get one for a 6 cylinder non-292
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 05-09-2012, 01:21 AM   #4
Captainfab
60-66 Nut
On the 292's the passenger side motor mount is in the forward set of holes, while the drivers side is in the rear set of holes. The passenger side motor mount bracket is shorter than the drivers side. The 230/250's have both motor mounts in the rear location, the same as for a small block.
Old 05-09-2012, 10:41 AM   #5
perro13
perro13's Avatar
so all i have to do is use the perch from a 250 & slide the mount back?
Old 05-09-2012, 10:46 AM   #6
1963c-10
1963c-10's Avatar
Yup
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 05-09-2012, 10:55 AM   #7
perro13
perro13's Avatar
Thanks,will the same motor mount work?
Old 05-10-2012, 01:19 AM   #8
Captainfab
60-66 Nut
The rubber part of the motor mount is the same from '63-'72 for all small blocks and I6 engines, so yes they will work.
Old 05-10-2012, 10:01 AM   #9
perro13
perro13's Avatar
Thanks guys but still a little confused. i know i can use the same rubber motor mount becuase 230,250 are the same as the v8. Now what im understandins is that the pass side frame mount, bracket is shorter on the pass side of a 292. So i would need to change to a 250 or a v8one? How about the one on the block. Sorry about all the questions, just wanna have everything when i go to install tomorrow.
Old 05-10-2012, 10:07 AM   #10
padresag
just the one on the frame
ron
padresag is offline   Reply With Quote
Old 05-10-2012, 10:31 AM   #11
perro13
perro13's Avatar
